[mapserver-users] Image not rendered on large monitors.
Subha Ramakrishnan
subha at gslab.com
Tue Dec 30 06:29:49 EST 2008
Thanks a lot for the reply.
I will try that and check if it works.
Thanks again.
Subha
thomas bonfort wrote:
> hi,
> set maxsize to something bigger, eg 4096
> regards,
> thomas
> On Tue, Dec 30, 2008 at 11:45, Subha Ramakrishnan <subha at gslab.com> wrote:
>> Hi,
>> We have built a map based web portal using Openlayers and Mapserver 5.0.2.
>> We have multiple layers being rendered using Mapserver.
>> But we are facing an issue here.
>> On large monitors with the resolutions, "1680 x 1050", "1856 x 1392" ,"1920
>> x 1080"(21 inches and above), mapserver doesn't render images.
>> It throws an error saying "WMS server error.Image size out of range,Width
>> and height must be between 1 and 2048 pixels."
>> I have tried setting the "MAXSIZE" as 2048 in my map file but it doesn't
>> seem to work.
>> My mapfile is as follows:
>> map
>> size 725 800
>> imagetype png
>> imagecolor 225 225 225
>> projection
>> "init=epsg:4326"
>> end
>> extent 60 0 100 40
>> maxsize 2048
>> outputformat
>> name "jpg"
>> driver "GD/JPEG"
>> extension "jpg"
>> formatoption "QUALITY=85"
>> end
>> layer
>> name xyz
>> connectiontype postgis
>> connection "user= abc dbname=qwe password=fgg host=localhost"
>> group world
>> type polygon
>> status on
>> data "topology from table"
>> class
>> style
>> width 3
>> outlinecolor 000 000 255
>> end
>> end
>> end
>> end
>> Is there something wrong that in the mapfile? Or if there is any other
>> solution that someone knows, please let me know.
>> Thanks for the help.
>> Regards,
>> Subha
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
