No subject
Fri Feb 8 15:06:04 EST 2008
SYMBOL
NAME "test_tt"
TYPE TRUETYPE
FONT "TTMITC__"
FILLED true
ANTIALIAS true
# Using symbol no 47 from MI transportation: 61440 + 47 =3D 61487
CHARACTER ""=20
END
Kind regards
=20
Bo Thomsen=20
GeoConsult I/S=20
Denmark
-----Oprindelig meddelelse-----
Fra: Flavio Hendry [mailto:flavio at TYDAC.CH]
Sendt: 19. august 2004 14:51
Til: MAPSERVER-USERS at LISTS.UMN.EDU
Emne: Re: [UMN_MAPSERVER-USERS] true type symbol
Hi Zolt=E1n
The webdings font is defined as "Microsoft Symbol" and as far as I know
not supported by MapServer. What you can do is to change the font
to "Microsoft Unicode" using i.e. Font Creator (http://www.high-
logic.com). Open the font, choose Format/Platform Manager, select
Microsoft Symbols and click on the button "change", which will switch
it to Unicode. Save and go ...
Mit freundlichem Gruss / Best Regards
Flavio Hendry
TYDAC NEWS http://www.tydac.ch/german/index.php?menu=3DNews_actual
############ Mit freundlichen Gruessen / Kind Regards
############ mailto:flavio at tydac.ch
############ TYDAC AG - http://www.tydac.ch
#### #### Geographic Information Solutions
#### #### Luternauweg 12 -- CH-3006 Bern
############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
-----Original Message-----
To: MAPSERVER-USERS at LISTS.UMN.EDU
Date: Thu, 19 Aug 2004 05:39:21 -0500
Subject: [UMN_MAPSERVER-USERS] true type symbol
> Hi list members,
> I've tried to use true type symbols. But black rectangles are
> displayed.
> Could you help me?
> Symbol definition:
> SYMBOL
> NAME "v"
> TYPE TRUETYPE
> FONT kozmufont
> FILLED true
> ANTIALIAS true
> # CHARACTER 'a'
> CHARACTER ' '
> END
> How should I define the character?
> fonts list contains
> kozmufont C:/windows/fonts/Webdings.ttf
> part of the map file
> LAYER
> NAME "kozmu"
> GROUP "kozter"
> CONNECTIONTYPE OGR
> CONNECTION "kozter/kozmu.tab"
> STATUS ON
> TYPE POINT
> MAXSCALE 501
> CLASS
> NAME 'K=F6zm=FB'
> SYMBOL 'v'
> SIZE 12
> COLOR 0 0 0
> END
> END
> c:\Program Files\Apache Group\Apache2\cgi-bin>mapserv -v
> MapServer version 4.2.1 OUTPUT=3DGIF OUTPUT=3DPNG OUTPUT=3DJPEG =
OUTPUT=3DWBMP
> OUTPUT=3DPDF OUTPUT=3DSWF SUPPORTS=3DPROJ SUPPORTS=3DFREETYPE
> SUPPORTS=3DWMS_SERVER
> SUPPORTS=3DWMS_CLI ENT SUPPORTS=3DWFS_SERVER SUPPORTS=3DWFS_CLIENT
> INPUT=3DPOSTGIS
> INPUT=3DOGR INPUT=3DGDAL INPUT=3DSHAPEFILE
