No subject
Fri Feb 8 15:06:04 EST 2008
the latter, but the east-west coordinates should be pushed together as
this formula would indicate: x=3Dlon*cos(lat) where lat is 60 and the
formula then gives x=3Dlon*0.5?
All I get is a blank map, so I suppose there is something I have misunderst=
ood?
Espen
On 16/01/2008, Ed McNierney <ed at topozone.com> wrote:
> Espen -
> The EPSG coordinate system codes, like EPSG:4326, generally are used to f=
ully specify a projection. If you need to "customize" a projection describ=
ed by an EPSG code, I would recommend using a full PROJ text description, a=
nd specify the use of the equirectangular (Plate Carr=E9e) projection:
> +proj=3Deqc +lat_ts=3D60 +lon_0=3D0 +x_0=3D0 +y_0=3D0 +datum=3DWGS84
> - Ed
> Ed McNierney
> Chief Mapmaker
> Demand Media / TopoZone.com
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> Phone: +1 (978) 251-4242
> Fax: +1 (978) 251-1396
