Problems using SLDs with negative values
Yewondwossen Assefa
yassefa at DMSOLUTIONS.CA
Fri Feb 1 10:01:36 EST 2008
Hi There,
Is it possible to send me directly a sample SLD (and if possible map and
data). I can check to see what the issue is.
Best Regards,
Juanma M. R. wrote:
> Hi all,
> We are working with SLDs in a webmapping application and we are having
> problems with negative values using Mapserver 4.10.1 y 4.10.2. Whenever
> we define an SLD clasified for a vector layer, if we define negative
> ranges it seems to colour all the negative ranges with the first
> negative range it founds.
> I would like to know if there is a bug or is a bad use from our side
> with SLDs. Does anyone know this kind of behabour?
> Cheers,
> Juanma.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
