insert a query_template into the HTML template
Pericles S. Nacionales
naci0002 at UMN.EDU
Mon Feb 4 16:20:23 EST 2008
Pericles S. Nacionales wrote:
> Steve Toutant wrote:
>> I created a map file and an HTML template with my own data following
>> the MapServer 5.x tutorial.
>> http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?root=%2Ftutorial&program=%2Fcgi-bin%2Fmapserv.exe&map=%2Fms4w%2Fapps%2Ftutorial%2Fhtdocs%2Fexample3.map&layer=states&zoom=0&map_web=template+example3-4.html+header+..%2Ftemplates%2Fexample3_header.html+footer+..%2Ftemplates%2Fexample3_footer_querymap.html&submit=Go+there%21
>> <http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?root=%2Ftutorial&program=%2Fcgi-bin%2Fmapserv.exe&map=%2Fms4w%2Fapps%2Ftutorial%2Fhtdocs%2Fexample3.map&layer=states&zoom=0&map_web=template+example3-4.html+header+..%2Ftemplates%2Fexample3_header.html+footer+..%2Ftemplates%2Fexample3_footer_querymap.html&submit=Go+there%21>
>> Section 3 explains how to create a query template. When the user
>> select a feature on the map the query template opens and shows the
>> result on a grid.
>> I would like this grid to appear in the HTML template just below the
>> map instead of appearing on a new page. Anyone knows if it possible?
>> thanks,
>> steve
> You should be able to do this by placing the query map stuff on the
> main header instead of the footer.
> -Perry
Once again, I jumped the gun. You can certainly do it--look at the
MapServer 5.x demo at http://mapserver.gis.umn.edu/download/current/ for
an example. You can use frames or DHTML for this.
-Perry
