insert a query_template into the HTML template
Pericles S. Nacionales
naci0002 at UMN.EDU
Mon Feb 4 16:16:26 EST 2008
Steve Toutant wrote:
> I created a map file and an HTML template with my own data following
> the MapServer 5.x tutorial.
> http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?root=%2Ftutorial&program=%2Fcgi-bin%2Fmapserv.exe&map=%2Fms4w%2Fapps%2Ftutorial%2Fhtdocs%2Fexample3.map&layer=states&zoom=0&map_web=template+example3-4.html+header+..%2Ftemplates%2Fexample3_header.html+footer+..%2Ftemplates%2Fexample3_footer_querymap.html&submit=Go+there%21
> <http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?root=%2Ftutorial&program=%2Fcgi-bin%2Fmapserv.exe&map=%2Fms4w%2Fapps%2Ftutorial%2Fhtdocs%2Fexample3.map&layer=states&zoom=0&map_web=template+example3-4.html+header+..%2Ftemplates%2Fexample3_header.html+footer+..%2Ftemplates%2Fexample3_footer_querymap.html&submit=Go+there%21>
> Section 3 explains how to create a query template. When the user
> select a feature on the map the query template opens and shows the
> result on a grid.
> I would like this grid to appear in the HTML template just below the
> map instead of appearing on a new page. Anyone knows if it possible?
> thanks,
> steve
You should be able to do this by placing the query map stuff on the main
header instead of the footer.
-Perry
