AGG and vertical line symbol
thomas bonfort
thomas.bonfort at GMAIL.COM
Wed Feb 6 14:11:08 EST 2008
if your trying to get hatching, you should probably be going with the
hatch symbol.
if not, could you post your layer definition and a screenshot of what
you're getting
regards,
thomas
On Feb 6, 2008 6:56 PM, Hunter, David - St. Louis Park, MN
<David.Hunter at fnis.com> wrote:
> When I use
> SYMBOL "line-vertical"
> in a class with AGG, the lines are broken up, looking like vertical dashes.
> Is there a workaround for this, or another symbol that works?
> David S. Hunter
> Lead Software Engineer
> Fidelity National Geographic Solutions
> division of Fidelity National Information Services
> 5353 Gamble Drive, Suite 201
> St. Louis Park, MN 55416
> Email: david.hunter at fnis.com
> Phone: 952.542.1440 ext. 256
> Fax: 952.542.3859
