[mapserver-users] Simple MrSid map file
Brent Fraser
bfraser at geoanalytic.com
Sun Feb 10 21:03:26 EST 2008
Ken,
I don't use MrSID, but here are some general things to look at:
1. Does your MrSID file have geo-referencing and coordinate system
definition information with it? Use GDAL's "gdalinfo" to find out.
2. Do your EXTENTS (with the related PROJECTION and UNITS) in the map file
actually cover/intersect the MrSID file?
3. Check your DATA value in the map file's LAYER. Is the path correct?
Is Mapserver able to access the file?
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
> Hi,
> I am trying to make ms4w show me a MrSid file. Eventually, I would like
> to be able to send center coordinates and dimensions and have it return a
> JPG.
> For now, however, I have apparently gotten into a tail chasing game -- no
> matter what I try, I seem to need to do something else first.
> I'm hoping that someone who uses MrSid files w/ ms4w could send me a
> "simplest" map file and html code that will allow me to display MrSid data
> over the web. This will give me a "solid place to stand" (or a safe
> position for a retreat) and I can add components and code from there.
> My MrSid file happens to be the NAIP file for McCook Co, SD. The file
> structure is like this: SD/mccook/..... files here.
> Sincerely,
> Ken
> mapserver-users at lists.osgeo.org
