[mapserver-users] Simple MrSid map file
Ken S. Elvehjem
elvehjem at runestone.net
Sun Feb 10 21:19:57 EST 2008
Brent,
Thanks for the response. I appreciate the *watch* items you included! and I
think that I have all that info available.
I think my main problem is that I cannot separate out what is *nice* in a
mapfile from what is *necessary* ... most of the examples I have been able
to find have multiple layers, labels, scales etc. that I may use one day,
but I have to comment them out because they don't apply. It's why I'm
trying to find the world's simplest mapfile that works for displaying raster
data... MrSID data if possible. A sort of a "Hello Raster (world)" Mapfile
for Mapserver.
I have been reading more about mapfiles @
http://umn.mapserver.ch/index_en.php . This has an astonishing amount of
information and is well organized.
Perhaps I should wait until I am over this bad head cold before I plow back
into it ;>)
Sincerest thanks!
Ken
----- Original Message -----
To: "Ken S. Elvehjem" <elvehjem at runestone.net>
Cc: <mapserver-users at lists.osgeo.org>
Sent: Sunday, February 10, 2008 8:03 PM
Subject: Re: [mapserver-users] Simple MrSid map file
> Ken,
> I don't use MrSID, but here are some general things to look at:
> 1. Does your MrSID file have geo-referencing and coordinate system
> definition information with it? Use GDAL's "gdalinfo" to find out.
> 2. Do your EXTENTS (with the related PROJECTION and UNITS) in the map file
> actually cover/intersect the MrSID file?
> 3. Check your DATA value in the map file's LAYER. Is the path correct?
> Is Mapserver able to access the file?
> Brent Fraser
> GeoAnalytic Inc.
> Calgary, Alberta
>> Hi,
>> I am trying to make ms4w show me a MrSid file. Eventually, I would like
>> to be able to send center coordinates and dimensions and have it return a
>> JPG.
>> For now, however, I have apparently gotten into a tail chasing game -- no
>> matter what I try, I seem to need to do something else first.
>> I'm hoping that someone who uses MrSid files w/ ms4w could send me a
>> "simplest" map file and html code that will allow me to display MrSid
>> data
>> over the web. This will give me a "solid place to stand" (or a safe
>> position for a retreat) and I can add components and code from there.
>> My MrSid file happens to be the NAIP file for McCook Co, SD. The file
>> structure is like this: SD/mccook/..... files here.
>> Sincerely,
>> Ken
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
