[mapserver-users] RE: [UMN_MAPSERVER-USERS] problem in configuration
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Mon Feb 11 11:29:37 EST 2008
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of orkun
> Sent: 11 February, 2008 4:01 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] problem in configuration
> hello
> I try to configure mapserver.
> But a part of configure.log shows:
> configure:1711: checking for C compiler default output file name
> configure:1714: gcc conftest.c >&5
> /usr/bin/ld: crt1.o: No such file: No such file or directory
> collect2: ld returned 1 exit status
> configure:1717: $? = 1
> configure: failed program was:
> | /* confdefs.h. */
> how can I solve the problem ?
(N.B. the new mailing list address)
I'm not a build guru, but, for starters, Can you specify:
- what operating system / platform you are attempting to build MapServer
on
- what is your full configure command
..Tom
