[mapserver-users] Simple thanks (re: Simple MrSID Map File)
Brent Fraser
bfraser at geoanalytic.com
Wed Feb 13 10:49:40 EST 2008
Ken (and all),
Thanks for the thanks :) For those new users searching
this list sometime in the future, below are the minimalist
steps to get mapserver to read a raster file and display it
in a browser (as Ken says, the "hello world" of web
mapping).
(0. Install ms2w and the Itasca demo dataset)
1. Make a map file using a text editor. Call it min.map and
put it in the Workshop directory (in your web server's
document-root directory).
MAP
NAME ITASCA
# ----- Output image properties -----
IMAGETYPE PNG # output type
SIZE 600 600 # image size in pixels
# ----- Output image spatial reference system
definition -----
# Output Projection - same as input data (UTM Zone 15,
NAD83),
# so no need to have MapServer re-project,
# therefor no PROJECTION object required
UNITS METERS
# minx miny maxx maxy (in meters)
EXTENT 423900 5205200 576000 5317000
# ----- Web interface definition -----
WEB
TEMPLATE "min.html" # the html Mapserver will send to
your browser
IMAGEPATH "C:\Inetpub\wwwroot\tmp\" # dir where
mapserver will
IMAGEURL "/tmp/" # create the
output image
END
# ----- Source data definition -----
LAYER
NAME "drg"
TYPE RASTER
STATUS DEFAULT # always "on"
DATA "C:\Inetpub\wwwroot\workshop\data\drgncimq1942.tif"
END
END # Map File
2. Make an html template file
The above map file relies on an html "template", stored in
the same directory as min.map, in our case named "min.html"
<html>
<body>
Hello World!<p>
<img src="[img]" width="[mapwidth]" height="[mapheight]" />
</body>
</html>
3. The URL you issue in your browser:
http://localhost/cgi-bin/mapserv.exe?map=c:\Inetpub\wwwroot\workshop\min.map
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
From: "Ken S. Elvehjem" <elvehjem at runestone.net>
To: <mapserver-users at lists.osgeo.org>
Sent: Wednesday, February 13, 2008 7:34 AM
Subject: [mapserver-users] Simple thanks (re: Simple MrSID
Map File)
Just a note to everyone to say how much I appreciate the
availability of this list.
A special thanks to Brent Fraser for his help... Was feeling
like I had wandered into *Looking Glass Land*... But Now...
my MrSID files are served up in a WMS server on my office
machine... and I know I couldn't have done it without his
comments, suggestions, and encouragement.
"A patch of ground in South Dakota:"
http://206.183.188.202/cgi-bin/mapserv.exe?map=c:\ms4w\Apache\htdocs\SD\mccook-wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=NAIP2006&STYLES=&SRS=EPSG:4269&BBOX=611300,4815500,613300,4817500&WIDTH=800&HEIGHT=800&FORMAT=image/jpeg
Sincerely,
Ken
Ken S. Elvehjem
ELVEHJEM TECHNICAL SUPPORT
250 Drury Ave
PO Box 37
Lowry MN 56349
320.283.5684
320.283.5247 h
320.424.1299 c
