[mapserver-users] RE: [UMN_MAPSERVER-USERS] Input Image and Image
Map
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Thu Feb 14 12:06:49 EST 2008
Matthew,
>From everything I see this should work. However, something you might try
doing is setup a little JavaScript that tracks the mouse movement (x,y)
within the map area and have those stored in a couple read-only form
fields. When you click on the map and the page is submitted you'll have
the x,y from those form fields to use in doing your zoom. I'm a little
swamped at the moment so until I can setup your code in a test
environment to interact with myself I'm probably not going to be much
more help. Sry.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Associate Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
