[mapserver-users] Query in frame with mapserv-demo doesn't work
Begoña Gonzalez
begodom at gmail.com
Fri Feb 15 03:58:20 EST 2008
Hello
Finally I fixed it.
The problem was a mixture of things, first the line: EMPTY
"/eiel/VACIO.html" in my WEB object and a bad coordinate realignment.
I don´t know why the reference of VACIO.html file was lost and because
my wrong coords mapserver never found records...
Add in WEB object the LOG optional File to log MapServer activity in
helped me to solve it.
Thanks
On Thu, Feb 14, 2008 at 9:02 AM, Begoña Gonzalez <begodom at gmail.com> wrote:
> hello david
> This is my map file, I send you only one layer but the others are similars:
> MAP
> NAME EIEL
> STATUS ON
> SIZE 600 600
> IMAGETYPE PNG
> IMAGECOLOR 249 249 249
> EXTENT 643925 4192100 645075 4197000
> TEMPLATEPATTERN "eiel"
> UNITS METERS
> IMAGETYPE PNG
> SHAPEPATH "datos"
> SYMBOLSET "c:/ms4w/apps/eiel2/etc/symbols.sym"
> FONTSET "c:/ms4w/apps/eiel2/etc/fonts.txt"
> WEB
> HEADER templates/header.html
> TEMPLATE "/ms4w/apps/eiel2/plantilla.html"
> FOOTER templates/footer.html
> MINSCALE 1000
> MAXSCALE 1550000
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> EMPTY "/eiel/VACIO.html"
> END
> LAYER
> NAME "ABASTECIMIENTO_A"
> STATUS ON
> TYPE POINT
> CONNECTIONTYPE oraclespatial
> CONNECTION "***/***@bbdd"
> DATA "GEOLOC FROM ***.**** USING UNIQUE MI_PRINX SRID 82337"
> CLASS
> STYLE
> SYMBOL "rechteck-hoch"
> COLOR 150 0 0
> SIZE 15
> OUTLINECOLOR 150 0 0
> END
> TEMPLATE "templates/ABASTECIMIENTO_A.html"
> END
> END
> #I have more layers but similars than previous....
> SCALEBAR
> STATUS ON
> LABEL
> COLOR 0 0 0
> ANTIALIAS ON
> SIZE TINY
> END
> UNITS METERS
> POSITION LR
> SIZE 150 3
> INTERVALS 3
> TRANSPARENT TRUE
> STYLE 1
> END
> REFERENCE
> STATUS ON
> IMAGE "ref/carto.gif"
> SIZE 160 110
> EXTENT 644125 4192100 647275 4199000
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> MINBOXSIZE 5
> MARKERSIZE 8
> MARKER 'star'
> END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> END
> END
> Thanks
> On Wed, Feb 13, 2008 at 9:10 PM, Fawcett, David
> <David.Fawcett at state.mn.us> wrote:
> > Please include the text of your map file.
> > -----Original Message-----
> > From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Begoña Gonzalez
> > Sent: Wednesday, February 13, 2008 2:00 PM
> > To: mapserver-users at lists.osgeo.org
> > Subject: [mapserver-users] Query in frame with mapserv-demo doesn't work
> > I already have my layers definition with template...
> > from Oscar ^_^ <oscarfbh at gmail.com> hide details 7:57 pm (58 minutes ago)
> > to Begoña Gonzalez <begodom at gmail.com>
> > date Feb 13, 2008 7:57 PM
> > subject Re: [mapserver-users] Query in frame with mapserv-demo doesn't work mailed-by gmail.com
> > Hello Begoña, to do a query in a layer You must put it queryable. Configure a TEMPLATE in your layer definition to make your layer queryable.
> > 2008/2/13, Begoña Gonzalez <begodom at gmail.com>:
> > > - Hide quoted text -
> > > Hello All
> > > I´m new with MapServer.I´m trying to build my aplication based in
> > > mapserv-demo. All the examples of mapserv-demo works fine. I´ve made a
> > > copy of all the files and rename the aplication. I want to have the
> > > same results as Adds dhtml rubber-band box. I´ve adapted the
> > > index.html, the itasca_adds_dhtml.html(renamed plantilla.html) and
> > > itasca.map (renamed eielmap.) In itasca_adds_dhtml.html and itasca.map
> > > I just changed regarding the layers and the map coordinates and size.
> > > The index.html file I have adapted in this way, to have my starup file
> > > and not having to choose the template in the select:
> > > <form method=GET action="frames_dhtml.html">
> > > <input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
> > > <input type="hidden" name="template" value="plantilla.html">
> > > <input type="hidden" name="zoomsize" value=2>
> > > <input type="hidden" name="map" value="/ms4w/apps/eiel2/eielmap.map">
> > > <input type="hidden" name="root" value="/eiel2/">
> > > <input type="hidden" name="map_web" value="IMAGEPATH
> > > '/ms4w/tmp/ms_tmp/' IMAGEURL '/ms_tmp/' TEMPLATE '/ms4w/apps/eiel2/plantilla.html'">
> > > </form>
> > > All works fine, the zoom bottons, the layers... except the query.
> > > When I do a query,into the bottom frame not show me anything, there is
> > > no error message of mapserver. The browser shows a message error: "no
> > > se puede encontrar la pagina web" "the web page is not found...", the
> > > url command is that this seems to be well:
> > > http://localhost/cgi-bin/mapserv.exe?mode=query&map=/ms4w/apps/eiel2/e
> > > ielmap.map&imgext=642050+4192100+646950+4197000&imgxy=317+187&imgbox=3
> > > 17+187+317+187&imgsize=400+400&layers=ABASTECIMIENTO_A+MANZANAS
> > > Thanks in advance and sorry form my english.
> > > Begoña
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/mapserver-users
