[MAPSERVER-USERS] loadWeb() error on Windows 2003 (MS4W package)
riteshambastha
ritesh.linux at gmail.com
Sat Feb 16 01:33:55 EST 2008
Well Suresh,
I just saw an error in your code.
Check this in your html code:
.... [img]................
Here, [img] catches the name of generated image file. This image file
resides in tmp directory. So, you will have to give it a path. Something
like /tmp/[img]. Play around this.. you will get your answer.
Regards,
Ritesh
<quote author=
Hi!
I have just started my exploration in Mapserver on Windows platform with
MS4W package. I am using Bil Kropla's Mapserver book. When I worked out the
first example (of chapter 2), a simple example using mapserver in CGI-BIN
mode, I get the following error
loadWeb(): Unknown identifier. Parsing error near (c):(line 1)
I tried changing the path information (TEMPLATE, IMAGE PATH), other
parameters to ensure the simple 'Hello World' example map gets displayed,
but I could not go further.
I am producing the source code below of the two files.
File: hello.map
# This is our "Hello World" mapfile
NAME "Hello World"
SIZE 400 300
IMAGECOLOR 249 245 186
IMAGETYPE png
EXTENT -1.0 -1.0 1.0 1.0
WEB
TEMPLATE "c:/ms4w/apache/htdocs/hello.html"
IMAGEPATH "c:/ms4w/apache/htdocs/tmp/"
IMAGEURL "/tmp/"
END
LAYER
STATUS default
TYPE point
FEATURE
POINTS 0.00 0.00 END
TEXT "Hello World"
END # end feature
CLASS
STYLE
COLOR 255 0 0
END
LABEL
TYPE bitmap
END
END
END
END
File: Hello.html
<html>
<head> <title>MapServer Hello World</title></head>
<body>
<form method=POST action="../cgi-bin/mapserv.exe">
<input type="submit" value="Click Me">
<input type="hidden" name="map"
value="c:/ms4w/apache/htdocs/hello.map">
<input type="hidden" name="map_web_imagepath"
value="c:/ms4w/apache/htdocs/tmp/">
</form>
[img]
</body>
</html>
Would appreciate any help on this.
Thanks in advance.
Suresh
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it
now.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://www.nabble.com/loadWeb%28%29-error-on-Windows-2003-%28MS4W-package%29-tp15506112p15515013.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
