[mapserver-users] WFS gml:null
Milo van der Linden
mlinden at zeelandnet.nl
Mon Feb 18 10:23:32 EST 2008
Thank you Bart for the response.
I tried BBOX'n my request.
I tried both:
- SRS=epsg:4326&bbox=-180,-90,-180,-90
and
- - SRS=epsg:28992&bbox=0,300000,300000,600000
But none of that did the trick..
Bart van den Eijnden (OSGIS) schreef:
> What happens if you add a BBOX filter to your request? You probably need to
> specify the coordinates in the SRS of your LAYER.
> The BBOX filter defaults to the Map's Extent which could be why it's
> returning 0 features since of the projection difference.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Milo van der Linden <mlinden at zeelandnet.nl>
> Naar: mapserver-users <mapserver-users at lists.osgeo.org>
> Onderwerp: [mapserver-users] WFS gml:null
> Datum: 18/02/08 10:39
>> Hello list!
>> I have been surfing the list all morning looking for a solution on why
>> my mapserver is returning a gml:null.
>> Couldn't find any documentation.
>> The problem:
>> I do a WFS request on a mapfile that contains a esri shapefile. The
>> layer I request has a different SRS than the main map.
> http://www.myserver.org/cgi-bin/mapserv.exe?map=awfsenabled.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getFeature&TYPENAME=percelen
>> it returns
>> <?xml version='1.0' encoding="ISO-8859-1" ?>
>> <wfs:FeatureCollection
>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>> xmlns:wfs="http://www.opengis.net/wfs"
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:ogc="http://www.opengis.net/ogc"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
> http://www.myserver.org/cgi-bin/mapserv.exe?map=awfsenabled.map&amp;SERVICE=WFS&amp;VERSION=1.0.0&amp;REQUEST=DescribeFeatureType&amp;TYPENAME=percelen&amp;OUTPUTFORMAT=XMLSCHEMA">
>> <gml:boundedBy>
>> <gml:null>missing</gml:null>
>> </gml:boundedBy>
>> </wfs:FeatureCollection>
>> Here is my layer definition.
>> The problem is whatever I do, whether I set wfs_extent or not, it keeps
>> returning gml:null
>> LAYER
>> NAME 'percelen'
>> TYPE POLYGON
>> DEBUG ON
>> TOLERANCE 1
>> DUMP TRUE
>> TEMPLATE 'ttt'
>> DATA '..mapdatardapercelen_laag_poly_merged.shp'
>> METADATA
>> "ows_title" "percelen"
>> "ows_srs" "EPSG:28992"
>> "gml_featureid" "id" ##REQUIRED
>> "wms_feature_info_mime_type" "text/html"
>> "ows_feature_info_mime_type" "text/html"
>> "wms_include_items"
>> "NEWFIELD2,NEWFIELD1,NEWFIELD3,HECTARES,PERIMETER,AREA"
>> "gml_include_items"
>> "gml_NEWFIELD2_alias" "Kadastraleaanduiding"
>> "gml_NEWFIELD3_alias" "Adres"
>> "gml_NEWFIELD1_alias" "Eigenaar"
>> "gml_HECTARES_alias" "Oppervlakte(Ha)"
>> "gml_AREA_alias" "Oppervlakte(m)"
>> "gml_PERIMETER_alias" "Omtrek(m)"
>> END
>> STATUS ON
>> #TRANSPARENCY 100
>> PROJECTION
>> "init=epsg:28992"
>> END
>> CLASS
>> NAME ''
>> STYLE
>> SYMBOL 0
>> SIZE 6
>> OUTLINECOLOR 180 208 208
>> #COLOR 180 208 208
>> END
>> END
>> END
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
