[mapserver-users] itemnquerymap output
Maxim Dubinin
sim at gis-lab.info
Mon Feb 18 13:13:28 EST 2008
yep, and it works ok when the map shows up without queries, so I assume
it can find it.
Maxim
Вы писали 18 февраля 2008 г., 11:53:24:
RG> That all looks good to me. is template.html in the same directory as
RG> your map file?
RG> Rich
RG> On Feb 18, 2008 9:35 AM, Maxim Dubinin <sim at gis-lab.info> wrote:
>> Here is a portion of my map file. As you can see, I'm trying to use
>> the same template.html to return result of the query back into it. It
>> works under WEB when it stats, but seems like ignored
>> under LAYER that is being queried (qlayer=states_poly,qitem=State).
>> Well not exactly ignored, if I don't put anything in there it gives
>> an error message.
>> MAP
>> IMAGETYPE PNG
>> EXTENT -97.238976 41.619778 -82.122902 49.385620
>> SIZE 400 300
>> SHAPEPATH "defquery/"
>> IMAGECOLOR 255 255 255
>> WEB
>> TEMPLATE "template.html"
>> IMAGEPATH "/tmp/"
>> IMAGEURL "/tmp/"
>> END
>> QUERYMAP
>> STATUS ON
>> SIZE 400 300
>> STYLE SELECTED
>> END
>> LAYER # States polygon layer begins here
>> NAME states_poly
>> DATA states_ugl
>> STATUS DEFAULT
>> TYPE POLYGON
>> CLASSITEM "CLASS"
>> METADATA
>> qstring_validation_pattern '.'
>> END
>> CLASS
>> NAME 'States'
>> Maxim
>> Вы писали 18 февраля 2008 г., 8:06:58:
>> RG> On Feb 17, 2008 9:53 PM, Maxim Dubinin <sim at gis-lab.info> wrote:
>> >> Thanks for suggestion, it was actually set. The strange thing is,
>> >> Mapserver doesn't care about what I put in there, as long as
>> >> LAYER\TEMPLATE "anything" exists. It could be any text as long
>> >> as its under LAYER\TEMPLATE, even if the file doesn't exist.
>> >> If I don't provide it, it gives me "msQueryByAttributes(): Query error. Requested
>> >> layer has no templates defined so is not queryable." error.
>> >> Is this template really for attributive results?
>> RG> The template is for either attribute or spatial (map) display. What
>> RG> gets displayed depends on the template. Maybe mapserver is not finding
>> RG> your template file?
>> RG> Rich
