[mapserver-users] itemnquerymap output
Richard Greenwood
richard.greenwood at gmail.com
Mon Feb 18 21:31:12 EST 2008
you have mode=itemquerymap but it should be mode=itemnquery
itemquerymap is not a valid mode.
Rich
On Feb 18, 2008 11:13 AM, Maxim Dubinin <sim at gis-lab.info> wrote:
> yep, and it works ok when the map shows up without queries, so I assume
> it can find it.
> Maxim
> Вы писали 18 февраля 2008 г., 11:53:24:
> RG> That all looks good to me. is template.html in the same directory as
> RG> your map file?
> RG> Rich
> RG> On Feb 18, 2008 9:35 AM, Maxim Dubinin <sim at gis-lab.info> wrote:
> >> Here is a portion of my map file. As you can see, I'm trying to use
> >> the same template.html to return result of the query back into it. It
> >> works under WEB when it stats, but seems like ignored
> >> under LAYER that is being queried (qlayer=states_poly,qitem=State).
> >> Well not exactly ignored, if I don't put anything in there it gives
> >> an error message.
> >> MAP
> >> IMAGETYPE PNG
> >> EXTENT -97.238976 41.619778 -82.122902 49.385620
> >> SIZE 400 300
> >> SHAPEPATH "defquery/"
> >> IMAGECOLOR 255 255 255
> >> WEB
> >> TEMPLATE "template.html"
> >> IMAGEPATH "/tmp/"
> >> IMAGEURL "/tmp/"
> >> END
> >> QUERYMAP
> >> STATUS ON
> >> SIZE 400 300
> >> STYLE SELECTED
> >> END
> >> LAYER # States polygon layer begins here
> >> NAME states_poly
> >> DATA states_ugl
> >> STATUS DEFAULT
> >> TYPE POLYGON
> >> CLASSITEM "CLASS"
> >> METADATA
> >> qstring_validation_pattern '.'
> >> END
> >> CLASS
> >> NAME 'States'
> >> Maxim
> >> Вы писали 18 февраля 2008 г., 8:06:58:
> >> RG> On Feb 17, 2008 9:53 PM, Maxim Dubinin <sim at gis-lab.info> wrote:
> >> >> Thanks for suggestion, it was actually set. The strange thing is,
> >> >> Mapserver doesn't care about what I put in there, as long as
> >> >> LAYER\TEMPLATE "anything" exists. It could be any text as long
> >> >> as its under LAYER\TEMPLATE, even if the file doesn't exist.
> >> >> If I don't provide it, it gives me "msQueryByAttributes(): Query error. Requested
> >> >> layer has no templates defined so is not queryable." error.
> >> >> Is this template really for attributive results?
> >> RG> The template is for either attribute or spatial (map) display. What
> >> RG> gets displayed depends on the template. Maybe mapserver is not finding
> >> RG> your template file?
> >> RG> Rich
Richard Greenwood
www.greenwoodmap.com
