[mapserver-users] Netcdf / WCS
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Feb 19 15:24:13 EST 2008
I need to think about this. For some reason I remember one of the test
cases being
just like this although with not so many bands. As the cobwebs clear I
believe this
was started but not completed. There's even a BANDSITEM member of the
layer object
defined in the source. This would allow definition of a column to map a
temporal value
to a particular band within a larger image. I'm thinking it's probably
not far from functioning.
Steve
>>> On 2/19/2008 at 10:08 AM, in message <47BAFEE1.60508 at pobox.com>,
Frank
Warmerdam <warmerdam at pobox.com> wrote:
> vincent wrote:
>> Hello,
>> I would like to create Web Coverage Service from one netCDF file in
>> following
http://mapserver.gis.umn.edu/docs/howto/WCSServerFormatHowTo
>> My netCDF store rainfall matrix every five minutes in the "pluie"
>> variable. This the CDL :
>> dimensions:
>> time = UNLIMITED; // (496 currently) // (has coord.var)
>> x = 50; // (has coord.var)
>> y = 50; // (has coord.var)
>> variables:
>> int Lambert_Conformal;
>> :grid_mapping_name = "lambert_conformal_conic";
>> :standard_parallel = 43.20317, 44.99683; // double
>> :longitude_of_central_meridian = 2.337229; // double
>> :latitude_of_projection_origin = 44.1; // double
>> :false_easting = 600.0; // double
>> :false_northing = 3200.0; // double
>> :_CoordinateTransformType = "Projection";
>> :_CoordinateSystems = "ProjectionCoordinateSystem";
>> :_CoordinateAxes = "y x";
>> :_CoordinateAxisTypes = "GeoX GeoY";
>> * double pluie(time=496, y=50, x=50);*
>> * :units = "mm/h";*
>> * :long_name = "Intensité de pluie";*
>> * :coordinates = "lat lon";*
>> * :grid_mapping = "Lambert_Conformal";*
>> * :_CoordinateSystems = "ProjectionCoordinateSystem
> LatLonCoordinateSystem";*
> Vincent,
> Because GDAL treats this array as a single dataset having 496 bands,
I don't
> believe there is a way to properly create a tileindex with one entry
per
> time slice, referring back directly to that band though this is
something
> that
> I think was discussed at one point.
> You *can* serve the pluie array, but it will be represented as having
496
> bands along a dimension called Band instead of time.
> Hopefully Steve will correct me if I am wrong. What would be nice
> is a way to have WCS (and raster rendering in general) potentially
> override the BANDS= processing option with information read from a
> tile index, and then update the gdaltindex program accordingly to
> generate such results. This shouldn't - in theory - be too hard to
> implement.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo,
http://osgeo.org
> mapserver-users at lists.osgeo.org
