[MAPSERVER-USERS] detecting memory leaks in java mapscript
rich.fromm
nospam420 at yahoo.com
Tue Feb 19 20:26:04 EST 2008
Any advice about tracking down memory leaks that might exist in java
mapscript?
For the context of why I'm trying to do this, see the following thread:
http://www.nabble.com/thread-safety-to15514019.html
I installed the debian sarge backport of valgrind (valgrind-3.2.0-Debian),
and
tried invoking java prefaced with:
valgrind --leak-check=full --smc-check=all -v
No leaks were reported, but I don't think it really checked where I wanted
it
to check. libmapscript.so is loaded with the following:
System.loadLibrary("mapscript");
And from the output it doesn't look like valgrind is actually instrumenting
that library, and I can't figure out how to tell it to explicitly instrument
a
dynamically loaded library.
Yet the valgrind FAQ:
http://valgrind.org/docs/manual/faq.html#faq.java
does indicate that this might at least be possible:
--- begin ---
in theory Valgrind can run any Java program just fine, even those that use
JNI and are partially implemented in other languages like C and C++. In
practice, Java implementations tend to do nasty things that most programs
do not, and Valgrind sometimes falls over these corner cases.
--- end ---
Sorry if this is more appropriately a valgrind question and not a mapserver
question, but I saw valgrind mentioned in a few places:
HISTORY.TXT
http://trac.osgeo.org/mapserver/ticket/2412
so I thought that maybe someone here might have experience as it relates to
this specific case.
- Rich
View this message in context: http://www.nabble.com/detecting-memory-leaks-in-java-mapscript-tp15580371p15580371.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
