[MAPSERVER-USERS] transparency problem - unable to see raster
undervector
Fawcett, David
David.Fawcett at state.mn.us
Wed Feb 20 13:46:13 EST 2008
Paul,
Try changing TRANSPARENCY ALPHA to TRANSPARENCY 30 (or OPACITY 30 if you
are using 5.0)
Either way, 30 refers to a 30% opacity value.
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Paul
McCullough
Sent: Wednesday, February 20, 2008 12:41 PM
To: mapserver-users at lists.osgeo.org
Subject: [MAPSERVER-USERS] transparency problem - unable to see raster
undervector
All,
I want to display a vector layer (roads) over a raster layer
(orthophoto). It seems that no matter what I try, the vector layer
remains opaque
and I cannot see the raster image in the background.
I have tried the following (some were in desperation):
- various incantations in the map file (see below)
- change layer order in map file (although last in map file comes out
on
top)
- tried calling out individual layers in URL
- read lots of nabble entries
Here is my basic URL:
http://10.1.15.68/cgi-bin/mapserv.exe?
&map=/ms4w/maps/hybrid.test.map
&LAYERS=hybrid
&UNITS=dd
&PROJECTION=EPSG%3A4326
&SERVICE=WMS
&VERSION=1.1.1
&REQUEST=GetMap
&STYLES=
&EXCEPTIONS=application%2Fvnd.ogc.se_inimage
&FORMAT=image%2Fjpeg
&SRS=EPSG%3A4326
&BBOX=-122.48949990400003,37.752500096,-122.42699980800003,37.815000192
&WIDTH=256
&HEIGHT=256
Here is my map file:
MAP
IMAGECOLOR 153 179 204
#IMAGETYPE PNG24
FONTSET fonts.list
OUTPUTFORMAT
NAME 'AGG'
#NAME 'AGG_PNG24'
DRIVER AGG/PNG
IMAGEMODE RGBA
#IMAGEMODE PC256
TRANSPARENT ON
#FORMATOPTION "transparent=on"
END
UNITS DD
TRANSPARENT TRUE
PROJECTION
"init=EPSG:4326"
END
WEB
IMAGEPATH "/tmp/"
IMAGEURL "tmp/"
METADATA
"wms_title" "a wms title"
"wms_srs" "EPSG:4326"
END
LOG "C:/ms4w/logs/mapserver.log"
END
SYMBOL
NAME "line_solid"
TYPE ellipse
POINTS 1 1 END
FILLED true
END
LAYER
NAME "level6"
GROUP "hybrid"
STATUS ON
TILEINDEX "..\data\level6.shp"
TILEITEM "Location"
TYPE RASTER
#TRANSPARENCY ALPHA
#TRANSPARENCY 50
OFFSITE 0 0 0
CLASS
MINSCALE 56001
MAXSCALE 100000
END
END
LAYER
NAME "roads_1"
GROUP "hybrid"
CONNECTIONTYPE postgis
CONNECTION "user=postgres password=postgres
dbname=postgis host=localhost port=5432"
DATA "the_geom from teleatlas_nw"
FILTER "freeway = '1'"
TYPE LINE
STATUS DEFAULT
TRANSPARENCY ALPHA
PROJECTION
"init=EPSG:102643"
END
LABELCACHE on
LABELITEM "name"
CLASS
NAME 'roads_1'
STYLE
COLOR 182 151 52
SYMBOL "line_solid"
SIZE 8
END
END
END
END
Thanks
Paul
View this message in context:
http://www.nabble.com/transparency-problem---unable-to-see-raster-under-
vector-tp15595301p15595301.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
