[mapserver-users] The right tool for the job
Milo van der Linden
mlinden at zeelandnet.nl
Wed Feb 20 15:03:44 EST 2008
Colin Wetherbee schreef:
> I would like my first step to be putting a static image on a web site.
> The image would be generated by Perl and returned to the browser as a
> simple image/png.
> The method I have in mind follows.
> Each user has a set of airports and routes with which they are
> concerned. This set of airports and routes could change as frequently
> as every 30 seconds. So, for each map generation request, I would
> dynamically create a map file and store it as TEXT in my PostgreSQL
> database, along with some unique ID. Then, I would output an <img />
> tag to the browser that includes the unique ID of this
> dynamically-generated map file:
Interesting approach. But you could also try:
http://www.someserver.org/cgi-bin/mapserv.exe?map=ergens.map&REQUEST=getmap&Layers=layer1,layer2,layer3&User=MyUser&Airport=1,5,23,56&airline=KLM&......
The mapfile is able to read user variables; this means
that the value MyUser that is in the variable User can be addressed in
the mapfile with %User%
Thus making it possible to have a layer that builds it's content from a
postGIS query dynamically like:
SELECT(THE GEOM) FROM Airports where ActiveUser=%User
This way you don't need to store mapfiles in the database and let the
form-variables in your webpage feed the dynamic content of the map.
Read the topic on
http://mapserver.gis.umn.edu/docs/reference/mapfile/variable_sub
The time stamp can also be set on a layer through a variable like this.
> <img src="/foo/mapImage.pl?id=1234" />
> mapImage.pl sees id=1234, pulls map file 1234 out of the database,
> uses the MapServer back-end to generate a map, then outputs this map
> as an image/png. I think mapImage.pl ends up being pretty simple:
> create a mapserver object, pipe the map file text to it, and get the
> png it generates. Is that it, or am I thinking too narrowly here?
> I may include a time stamp, too, so I can expire map files after some
> length of inactivity.
> Does this sound about right?
> Thanks for your help. :)
> Colin
> mapserver-users at lists.osgeo.org
