Antwort: Re: [MAPSERVER-USERS] leaking memory in java mapscript (was
Re: thread safety)
umn-ms at hydrotec.de
Thu Feb 21 02:36:54 EST 2008
Hi
> I don't totally understand how all of the SWIG stuff works, but I can
follow
> it a bit. The source for this is:
It's easier to watch the SWIG-generated JNI-Code in
mapscript/java/mapscript_wrap.c
Example:
mapscriptJNI.delete_imageObj(swigCPtr);
is implemented by the C-function
SWIGEXPORT jbyteArray JNICALL
Java_edu_umn_gis_mapscript_mapscriptJNI_imageObj_1getBytes
> confirm that the caller must free the returned array (with gdFree()).
At the end of the long-named C-function you'll find a call to gdFree
Can you estimate how much memory is lost in each step of your
testprogram? Is it approx. the size of the image?
Benedikt Rothe
mapserver-users-bounces at lists.osgeo.org schrieb am 21.02.2008 03:31:09:
> rich.fromm wrote:
> > Other than calling delete() on every mapserver object as applicable,
is
> > there
> > anything else that I can be doing? I fear that there may be a real
> > genuine
> > leak within mapserver, and that that might be hard to track down.
> I have narrowed this down to a smaller testcase, that only has two
mapscript
> objects.
> I have a fixed map file, and I'm doing barely anything, just creating
the
> map
> object from the map file, drawing to the image object, and getting the
> bytes.
> I am calling both map.delete() and img.delete() at the end. Then I loop
> over
> all of this repeatedly.
> This is a little bit of a simplification, but essentially what I'm doing
is
> this:
> for (int i = 0; i < loop; i++) {
> mapObj map = null;
> imageObj img = null;
> try {
> map = new mapObj(filename);
> img = map.draw();
> byte[] bytes = img.getBytes();
> } catch (Exception e) {
> System.err.println("Caught exception: " + e);
> e.printStackTrace(System.err);
> } finally {
> if (img != null) {
> img.delete();
> if (map != null) {
> map.delete();
> System.gc();
> } // end for
> I have tried a number of variants of this (including outputting the
bytes to
> a
> file), and the offending line seems to be the call to
imageObj.getBytes().
> With it, my program leaks. Without it, it does not:
> [rich at peyote mapserver_test 17:53:31]$ <mapserver_test> diff -u
> java/src/TestMapscript.java.bak1 java/src/TestMapscript.java.bak3
> --- java/src/TestMapscript.java.bak1 2008-02-20 17:37:43.000000000
-0800
> +++ java/src/TestMapscript.java.bak3 2008-02-20 17:53:27.000000000
-0800
> @@ -1,4 +1,4 @@
> -// this code does NOT leak
> +// this code DOES leak
> import edu.umn.gis.mapscript.mapObj;
> import edu.umn.gis.mapscript.imageObj;
> @@ -47,7 +47,7 @@
> System.err.println("Drawing map to image object");
> img = map.draw();
> -// byte[] bytes = img.getBytes();
> + byte[] bytes = img.getBytes();
> // int width = img.getWidth();
> // int height = img.getHeight();
> // System.err.println("The image is of size " + width + " x
> height + " and contains " + bytes.length + " bytes");
> [rich at peyote mapserver_test 17:53:53]$ <mapserver_test>
> I am calling System.gc() at the end of each iteration. And by examining
the
> memory from java's perspective (Runtime.getRuntime().freeMemory() and
> Runtime.getRuntime().totalMemory()) I can see that it is reasonably
stable.
> However, the memory as reported by top gradually grows.
> The source for imageObj.getBytes() is as follows:
> mapscript/java/edu/umn/gis/mapscript/imageObj.java
> public byte[] getBytes() {
> return mapscriptJNI.imageObj_getBytes(swigCPtr);
follow
> getBytes() (mapscript/swiginc/image.i)
> which notes the following:
> getBytes returns a gdBuffer structure (defined in mapscript.i) which
> must
> be typemapped to an object appropriate to the target language. This
> typemap must also gdFree the data member of the gdBuffer. See the
type-
> maps in java/javamodule.i and python/pymodule.i for examples.
> contributed by Jerry Pisk, jerry.pisk at gmail.com
> And all of the following:
> msSaveImageBuffer() (maputil.c)
> msSaveImageBufferAGG() (mapagg.cpp)
> msSaveImageBufferGD() (mapgd.c)
> What's not entirely clear to me is whether "the caller" means the java
> mapscript code, or the application writer. In other words, am I
responsible
> for doing this, or should this happen when I call img.delete() ? Here
is
> the
> code for imageObj.delete():
> public void delete() {
> if(swigCPtr != 0 && swigCMemOwn) {
> swigCMemOwn = false;
> swigCPtr = 0;
> But even though I don't see a call to gdFree() there, it's not clear to
me
> that it's not happening somewhere. I don't understand the SWIG path
enough,
> and I haven't yet tried following it in gdb. (Although that might be
worth
> trying.)
> If I am responsible for doing this, how do I do it? It appears to me
that
> gdFree() is not part of the mapscript API (it doesn't appear in the
docs),
> and
> just that it is just a mapscript internal function.
> Right now my test case is using a fairly complicated mapfile from a
large
> data
> source located in a postgis database. I will try to see if I can
replicate
> this problem with a simpler map file and/or synthetic data.
> But in the mean time I wanted to post this in case anyone might have
some
> advice based on these observations.
> Once again, thanks for any help that anyone might be able to provide.
> - Rich
> p.s. This is all based on mapserver 5.0.0
> View this message in context: http://www.nabble.com/thread-safety-
> tp15514019p15603603.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080221/fd0b46e8/attachment.html
