[mapserver-users] can an ogr tileindex refer to a PG table?
Milo van der Linden
mlinden at zeelandnet.nl
Thu Feb 21 16:46:09 EST 2008
Hello Neil,
One thing you can do to create some sort of tileindex that can be part
of the where clause is create a view in postGIS that contains the
boundingboxes of a table based upon an attribute:
CREATE VIEW MYBBOX AS
SELECT
table1.uniqueID,
extent(table1.the_geom) as box,
box2d(scale(extent(table1.the_geom),1.01,1.01)) as bbox
FROM
table1
GROUP BY
table1.UniqueID;
Where BOX is the exact extent and bbox is the extent + a little margin,
this I used to zoom with an area around it because my original MYBBOX
view was based on a points table.
This view could be used as a helper to build the right queries.
Wouldn't it be more performance effective
Neil Best schreef:
> Last fall I got some help for the list on how to use Postgres as a
> source for a tile index that gives locations of raster files on disk
> and that has been working beautifully.
> My new question is this: Is it possible for a tile index location to
> indicate something other than a path to a file, such as a PostGIS table?
> The reason that I ask is that I have implemented table partitioning
> for large county-by-county (or smaller) data sets such as SSURGO and
> USDA CLU. At the outset I convinced myself mistakenly that Postgres
> could leverage spatial check constraints for query planning using the
> constraint_exclusion = on mechanism, but it can't. It only works with
> fields where the check constraint is based on a straight
> equal/not-equal comparison to a constant, AFAICT. Neither &&
> ::geometry or ~ ::text checks work for this reason.
> Getting Mapserver to leverage this advanced query planning means
> adding logic to my application to inject appropriate values into a
> WHERE clause in the layer's DATA query string. To do this I need some
> kind of generalized layer that indicates the spatial organization of
> the attributes used for the partitioning. This is essentially a tile
> index, so if I could just create a layer of bounding boxes for each
> table and let Mapserver decide which tables it needs to scan rather
> than adding complexity to my application in order to have the query
> planner do the same thing, that would be ideal.
> Anybody have any thoughts or experiences to share? Thanks.
> Neil
> mapserver-users at lists.osgeo.org
