[MAPSERVER-USERS] Antwort: Re: leaking memory in java mapscript
(was Re: thread safety)
rich.fromm
nospam420 at yahoo.com
Thu Feb 21 17:58:56 EST 2008
rich.fromm wrote:
> I have finally been able to successfully run a single iteration in
> valgrind
> and have it report a leak in the code:
> --- begin ---
> ==21154== 41,600 bytes in 65 blocks are possibly lost in loss record 46 of
> 55
> ==21154== at 0x401C6CA: calloc (vg_replace_malloc.c:279)
> ==21154== by 0x42B15E3: gdCalloc (gdhelpers.c:79)
> ==21154== by 0x42A4F49: gdImageCreate (gd.c:104)
> ==21154== by 0x40BFEA9: msImageCreateWithPaletteGD (mapgd.c:3460)
> ==21154== by 0x40C04E8: msSaveImageBufferGD (mapgd.c:3695)
> ==21154== by 0x40CCD6B: msSaveImageBufferAGG (mapagg.cpp:2248)
> ==21154== by 0x40A70F8: msSaveImageBuffer (maputil.c:682)
> ==21154== by 0x406CB6C:
> Java_edu_umn_gis_mapscript_mapscriptJNI_imageObj_1getBytes
> (mapscript_wrap.c:2586)
> ==21154== by 0x88614AA: ???
> ==21154== by 0x885BA63: ???
> ==21154== by 0x8859218: ???
> ==21154==
> ==21154==
> ==21154== 271,588 (7,268 direct, 264,320 indirect) bytes in 1 blocks are
> definitely lost in loss record 49 of 55
> ==21154== at 0x401D38B: malloc (vg_replace_malloc.c:149)
> ==21154== by 0x42B15AC: gdMalloc (gdhelpers.c:85)
> ==21154== by 0x42A4EA4: gdImageCreate (gd.c:83)
> --- end ---
Here's my hunch from a somewhat cursory inspection of the code.
This is around mapgd.c:3691:
unsigned char *msSaveImageBufferGD(gdImagePtr img, int *size_ptr,
outputFormatObj *format)
unsigned char *imgbytes;
if( force_palette ) {
gdImagePtr gdPImg;
const char *palette = msGetOutputFormatOption( format, "PALETTE",
"palette.txt");
gdPImg = msImageCreateWithPaletteGD(img, palette, gdImageSX(img),
gdImageSY(img));
msImageCopyForcePaletteGD(img, gdPImg);
imgbytes = gdImagePngPtr(gdPImg, size_ptr);
return imgbytes;
the (gdImagePtr gdPImg) is a pointer to the bytes created by the gd code.
But what is returned to mapscript (see the function below from around
mapscript_wrap.c:2581), is the (unsigned char *imgbytes) above.
SWIGINTERN gdBuffer imageObj_getBytes(imageObj *self){
buffer.data = msSaveImageBuffer(self, &buffer.size, self->format);
return buffer;
so when the JNI wrapper calls gdFree() at mapscript_wrap.c:25804:
JNIEXPORT jbyteArray JNICALL
Java_edu_umn_gis_mapscript_mapscriptJNI_imageObj_1getBytes(JNIEnv *jenv,
jclass jcls, jlong jarg1) {
jbyteArray jresult = 0 ;
result = imageObj_getBytes(arg1);
jresult = SWIG_JavaArrayOutSchar(jenv, (&result)->data, (&result)->size);
if( (&result)->owns_data ) gdFree((&result)->data);
return jresult;
it's only the (unsigned char *imgbytes) from above (mapgd.c) that gets
freed,
leaking the original (gdImagePtr gdPImg) allocated by the gd code.
At least that's my guess, still exploring further.
Perhaps I should try to recreate this as a self contained test case, and
then
I could file a bug.
- Rich
View this message in context: http://www.nabble.com/thread-safety-tp15514019p15622039.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
