[mapserver-users] Map image location
Fawcett, David
David.Fawcett at state.mn.us
Thu Feb 21 22:04:51 EST 2008
Gerry,
A little more info would be helpful. How are you calling MapServer? If
you are calling it in mode=map, no image is generated in the tmp
directory. In browse (the default) mode, a temp image is created.
What happens when you call MapServer, are you getting the image that you
expect in the browser? Are you getting an error?
The URL string that you are using to call MapServer and the text of your
map file would be helpful.
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Gerry
James
Sent: Thursday, February 21, 2008 4:33 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Map image location
I have a bit of a dilemma. I have built an application using
UMN Mapserver as the mapping front end. Part of the application
requires I retrieve the current map image, however, when I go to look
for it where I think it should be /tmp/ms_tmp/ there are no images to
be found. Can someone help me find where these images are being stored.
I am using the ms4w MapServer version.
Any guidance would be greatly appreciated.
Gerry
___________________________________
Gerry James, B.Sc., GISP
President/Lead Consultant
Carteryx Geomatics Consultants Inc.
Spatial Intelligence for a Changing World
www.carteryx.com
The information contained in this e-mail is intended only for
the recipient(s) to whom it is addressed and its contents (including any
attachments) may contain information that is confidential or privileged.
Any unauthorized review, use, dissemination, copying or distribution is
strictly prohibited. If you are not the named recipient of this email or
have received it in error, please notify the sender and destroy and
delete all copies of the email immediately.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080221/3b9ef5c1/attachment.html
