[mapserver-users] Problem with Java Mapscript to dinamyc connection
on OGR
m.manso at upm.es
m.manso at upm.es
Fri Feb 22 10:39:09 EST 2008
I'm trying to use mapscript to draw a vector or raster layer.
I've see Java Mapscript examples in with you can start from emty mapfile, and build as you
like.
In this situacion you can add layer as you like RASTER, VECTOR with different
connectiontype.
When i tryal to connect using OGR and layer.setData() path to DGN file for example no error
happened but when try to draw layer one error appear.
I'm using Mapserver 5.1-dev version.
Can any one help me to find problem?
Thanks
Miguel Ángel Manso Callejo.
Grupo Mercator: Tecnologías de la Geoinformación.
Dpto. Ing. Topográfica y Cartografía (UPM)
ETSI en Topografía, Geodesia y Cartografía.
Autovia de Valencia Km 7.5 Madrid 28031
Tfno: 34 91 336 6487 - Fax: 34 91 336 7932
