[MAPSERVER-USERS] Antwort: Re: leaking memory in java mapscript
(was Re: thread safety)
Tamas Szekeres
szekerest at gmail.com
Fri Feb 22 07:01:04 EST 2008
2008/2/22, rich.fromm <nospam420 at yahoo.com>:
> The actual memory allocation happens in gdImageCreate() in gd.c, which
> returns
> gdImagePtr im.
> This sets gdImagePtr img in msImageCreateWithPaletteGD() in mapgd.c, which
> returns it.
> This then sets gdImagePtr gdPImg in msSaveImageBufferGD() in mapgd.c. This
> value is NOT directly returned. Instead, it is used to set unsigned char
> *imgbytes, and that is returned.
I think this might be the case. Would you try adding something like:
Index: mapgd.c
--- mapgd.c (revision 7383)
+++ mapgd.c (working copy)
@@ -3686,6 +3686,8 @@
gdPImg = msImageCreateWithPaletteGD(img, palette,
gdImageSX(img), gdImageSY(img));
msImageCopyForcePaletteGD(img, gdPImg, method);
imgbytes = gdImagePngPtr(gdPImg, size_ptr);
+ if (gdPImg)
+ gdImageDestroy(gdPImg);
else if ( force_pc256 ) {
gdImagePtr gdPImg;
@@ -3704,6 +3706,8 @@
for( i = 0; i < gdPImg->colorsTotal; i++ )
gdPImg->open[i] = 0;
+ if (gdPImg)
else
imgbytes = gdImagePngPtr(img, size_ptr);
If this fix is helpful then attach it to the ticket please.
Best regards,
Tamas
