[MAPSERVER-USERS] Problem with Java Mapscript to dinamyc
connection on OGR
rich.fromm
nospam420 at yahoo.com
Sun Feb 24 15:55:26 EST 2008
m.manso wrote:
> when try to draw layer one error appear.
In general you might get a better chance at a response if you post at least
a snippet of the problematic java mapscript code, as well as the exact
details of what the error is. the mapfile would also be relevant if there
was one, although it sounds like you might not have one in your case, if
you're building up the entire mapobj by scratch. (personally, i wasn't able
to get that to do what i want, so i use a series of map files as templates
and then use java mapscript to modify them as needed for each particular
request, but ymmv.)
- rich
View this message in context: http://www.nabble.com/Problem-with-Java-Mapscript-to-dinamyc-connection-on-OGR-tp15636757p15669214.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
