[mapserver-users] Re: Query Regrading Map Server
Kunal Malik
kunal.malik81 at gmail.com
Wed Feb 27 23:23:58 EST 2008
Hi Brent!!
U have Written that it does not allow the layer & its objects.
if we were having the requirement of editing the layer.is that not
possible.Moreover i want to know that does MapServer + openGl works for the
following .
1.Import & Export Maps
2.Create,Delete & Edit Layers
3.ReProjection of Data.
4.Conversion of Map from one datum & projection to Datum wgs84 & Proejction
LCC.
5.Raster to Vector conversion & vice versa
6. Set Transparency.
7. Layer priority,
Please Suggest the requirement could be fulfliied by Mapserver and all the
data would be displayed on OpenGL.
could grass be helpful in this regard??
Thanks
On 2/27/08, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Kunal,
> If OpenGL is a strict requirement, you may want to look at
> VTP (www.vterrain.org), or ossimPlanet (www.ossim.org).
> Neither allow editing of map data but you can add/delete
> layers. I think they will do the other requirements you
> listed.
> Brent Fraser
> GeoAnalytic Inc.
> Calgary, Alberta
> ----- Original Message -----
> From: "Kunal Malik" <kunal.malik81 at gmail.com>
> To: "vishal nagpal" <vishu73ns at gmail.com>
> Cc: <mapserver-users at lists.osgeo.org>
> Sent: Tuesday, February 26, 2008 10:54 PM
> Subject: [mapserver-users] Re: Query Regrading Map Server
> > Hi Vishal!!
> > 1.
> > As far as the compatibilty with the opengl is concerned i
> am asking this
> > because my display module is made on opengl and i have to
> display the raster
> > & the vector image on it.....
> > 2.
> > we don't have to use the web-server as our application
> will run on intranet
> > ..we want that mapserver to interact with opengl..
> > 32 client take the map from the central map server and
> display on their
> > screen which is on opengl..
> > can u suggest ..how should i approach this ..i don;t have
> any idea about the
> > mapserver programming is concerned...
> > can u suggest any sample code which i could run on my
> machine so as to check
> > the compatibilty,
> > or any docs that u can refer ..
> > 3.
> > I was looking for the grass option ..Do u have any idea
> ..that does grass
> > also need the mapserver to maintain the repository of
> data.,,
> > Looking forward for ur Reply.
> > Thanks
> > On 2/27/08, vishal nagpal <vishu73ns at gmail.com> wrote:
> > > Hi Kunal,
> > > 1. I do not have much experience on grass. but i hv read
> a little about
> > > it.
> > > 2. All the six requirements mentioned below can be done
> with both Grass
> > > and Mapserver.
> > > 3. What I know, GRASS is a very good and exhaustive
> software.
> > > Mapserver also has lot of features that GRASS has.
> > > 3. Mapserver is an ideal solution if you wish to use web
> based service.
> > > However, it also works on a Server-client model also.
> > > 4. I am not too sure why you need compatibility with
> OpenGL. Probably you
> > > wish to see the data in 3D. Both these servers represent
> data in 2D only.
> > > all the best
> > > Regards,
> > > Vishal
> > > On Tue, Feb 26, 2008 at 7:01 PM, Kunal Malik
> > > wrote:
> > > > Hi Vishal !!
> > > > I am working on Grass Tool & also Looking for
> map-server.
> > > > I have following requirement.,.
> > > > 1)Importing of Raster & Vector Maps.
> > > > 2) Re-Projection
> > > > 3)Create & Edit layer.
> > > > 4)Display Maps
> > > > 5)Set Transparency
> > > > 6)Stiching of Maps
> > > > and so on..
> > > > I have to use the GIS feature,,
> > > > I am told to look all this on open-source tool,,,so i
> am looking it on
> > > > Grass and Mapserver..my display is on OpenGL..also i
> have to take care that
> > > > tool i use should work with opengl..
> > > > can u suggest that going for grass & Mapserver..would
> able to resolve
> > > > all the requirements.
> > > > Thanks
> > > > On 2/26/08, vishal nagpal <vishu73ns at gmail.com> wrote:
> > > > > hi i hv seen ur queries in mapserver list how can i
> help u. i hav been
> > > > > wkg on mapserver for around six months now,
> > > > > Regards,
> > > > > Vishal
> > > > Thanks & Regards
> > > > Kunal Malik
> > > > 09871147561
> > Thanks & Regards
> > Kunal Malik
> > 09871147561
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080228/a8cd2187/attachment-0001.html
