[mapserver-users] symbology showing line direction
Fawcett, David
David.Fawcett at state.mn.us
Fri Feb 29 09:19:05 EST 2008
Adam,
What does your layer definition, with the classes look like?
Does your data have the direction column properly populated for all
records?
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Adam Feidt
Sent: Friday, February 29, 2008 8:14 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] symbology showing line direction
I'm working in a GeoMoose application and trying to
display utility lines with the correct line direction via some arrow
character or symbol. I've had no luck so far. I've successfully
labeled my lines with a truetype font character by defining the TEXT ">"
parameter in the CLASS object. I've also tried a pixelmap symbol
definition using a .gif file. Both appear to work at first, but when
you compare it to the actual line direction it isn't true in all cases.
Has anybody found a way to accomplish this? I would appreciate if you
could send me any examples.
Adam M. Feidt
GIS Coordinator
City of Eden Prairie
8080 Mitchell Rd
Eden Prairie, MN 55344
phone# 952-949-8443
fax# 952-949-8334
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080229/6f10d017/attachment.html
