[mapserver-users] symbology showing line direction
G. Allegri
giohappy at gmail.com
Fri Feb 29 09:57:09 EST 2008
A question: how can you derive a line direction by a shp without
having an appropriate attribute?
Giovanni
2008/2/29, Adam Feidt <afeidt at edenprairie.org>:
> David,
> Below is my Layer definition. I've tried a truetype symbol and label
> with the ANGLE parameter set to AUTO or FOLLOW. Neither case pointed out
> actual shapefile line direction. I'm reading an ESRI shapefile so there is
> no specific column for line direction.
> LAYER
> NAME 'Utilities Sanitary Lines'
> DATA './UtilitiesSanitaryLines.shp'
> TYPE LINE
> STATUS DEFAULT
> CLASSITEM "Function"
> CLASS
> NAME 'Main'
> EXPRESSION ""
> STYLE
> COLOR 85 255 0
> SYMBOL "plainline"
> SIZE 2
> END
> END # end class
> CLASS
> NAME 'Low Pressure'
> EXPRESSION "Low Pressure"
> STYLE
> COLOR 255 85 0
> SYMBOL "plainline"
> SIZE 2
> END
> END # end class
> CLASS
> NAME 'Sub Trunk'
> EXPRESSION "Sub Trunk"
> STYLE
> COLOR 85 255 0
> SYMBOL "plainline"
> SIZE 2
> END
> END # end class
> CLASS
> NAME 'Trunk'
> EXPRESSION "Trunk"
> STYLE
> COLOR 112 168 0
> SYMBOL "plainline"
> SIZE 2
> END
> END # end class
> CLASS
> NAME 'Force Main'
> EXPRESSION "forcemain"
> STYLE
> COLOR 255 170 0
> SYMBOL 'dashed1'
> SIZE 2
> END
> END # end class
> CLASS
> NAME 'Private'
> EXPRESSION "private"
> STYLE
> COLOR 161 33 240
> SYMBOL 'plainline'
> SIZE 2
> END
> END # end class
> END #end layer
> Adam M. Feidt
> GIS Coordinator
> City of Eden Prairie
> 8080 Mitchell Rd
> Eden Prairie, MN 55344
> phone# 952-949-8443
> fax# 952-949-8334
> From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
> Sent: Friday, February 29, 2008 8:19 AM
> To: Adam Feidt; mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] symbology showing line direction
> Adam,
> What does your layer definition, with the classes look like?
> Does your data have the direction column properly populated for all records?
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf
> Of Adam Feidt
> Sent: Friday, February 29, 2008 8:14 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] symbology showing line direction
> I'm working in a GeoMoose application and trying to display utility
> lines with the correct line direction via some arrow character or symbol.
> I've had no luck so far. I've successfully labeled my lines with a truetype
> font character by defining the TEXT ">" parameter in the CLASS object. I've
> also tried a pixelmap symbol definition using a .gif file. Both appear to
> work at first, but when you compare it to the actual line direction it isn't
> true in all cases. Has anybody found a way to accomplish this? I would
> appreciate if you could send me any examples.
> Adam M. Feidt
> GIS Coordinator
> 8080 Mitchell Rd
> phone# 952-949-8443
> fax# 952-949-8334
