[mapserver-users] symbology showing line direction
G. Allegri
giohappy at gmail.com
Fri Feb 29 10:01:19 EST 2008
I mean, shapefile is not topological...
2008/2/29, G. Allegri <giohappy at gmail.com>:
> A question: how can you derive a line direction by a shp without
> having an appropriate attribute?
> Giovanni
> 2008/2/29, Adam Feidt <afeidt at edenprairie.org>:
> > David,
> > Below is my Layer definition. I've tried a truetype symbol and label
> > with the ANGLE parameter set to AUTO or FOLLOW. Neither case pointed out
> > actual shapefile line direction. I'm reading an ESRI shapefile so there is
> > no specific column for line direction.
> > LAYER
> > NAME 'Utilities Sanitary Lines'
> > DATA './UtilitiesSanitaryLines.shp'
> > TYPE LINE
> > STATUS DEFAULT
> > CLASSITEM "Function"
> > CLASS
> > NAME 'Main'
> > EXPRESSION ""
> > STYLE
> > COLOR 85 255 0
> > SYMBOL "plainline"
> > SIZE 2
> > END
> > END # end class
> > CLASS
> > NAME 'Low Pressure'
> > EXPRESSION "Low Pressure"
> > STYLE
> > COLOR 255 85 0
> > SYMBOL "plainline"
> > SIZE 2
> > END
> > END # end class
> > CLASS
> > NAME 'Sub Trunk'
> > EXPRESSION "Sub Trunk"
> > STYLE
> > COLOR 85 255 0
> > SYMBOL "plainline"
> > SIZE 2
> > END
> > END # end class
> > CLASS
> > NAME 'Trunk'
> > EXPRESSION "Trunk"
> > STYLE
> > COLOR 112 168 0
> > SYMBOL "plainline"
> > SIZE 2
> > END
> > END # end class
> > CLASS
> > NAME 'Force Main'
> > EXPRESSION "forcemain"
> > STYLE
> > COLOR 255 170 0
> > SYMBOL 'dashed1'
> > SIZE 2
> > END
> > END # end class
> > CLASS
> > NAME 'Private'
> > EXPRESSION "private"
> > STYLE
> > COLOR 161 33 240
> > SYMBOL 'plainline'
> > SIZE 2
> > END
> > END # end class
> > END #end layer
> > Adam M. Feidt
> > GIS Coordinator
> > City of Eden Prairie
> > 8080 Mitchell Rd
> > Eden Prairie, MN 55344
> > phone# 952-949-8443
> > fax# 952-949-8334
> > From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
> > Sent: Friday, February 29, 2008 8:19 AM
> > To: Adam Feidt; mapserver-users at lists.osgeo.org
> > Subject: RE: [mapserver-users] symbology showing line direction
> > Adam,
> > What does your layer definition, with the classes look like?
> > Does your data have the direction column properly populated for all records?
> > David.
> > -----Original Message-----
> > From: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf
> > Of Adam Feidt
> > Sent: Friday, February 29, 2008 8:14 AM
> > To: mapserver-users at lists.osgeo.org
> > Subject: [mapserver-users] symbology showing line direction
> > I'm working in a GeoMoose application and trying to display utility
> > lines with the correct line direction via some arrow character or symbol.
> > I've had no luck so far. I've successfully labeled my lines with a truetype
> > font character by defining the TEXT ">" parameter in the CLASS object. I've
> > also tried a pixelmap symbol definition using a .gif file. Both appear to
> > work at first, but when you compare it to the actual line direction it isn't
> > true in all cases. Has anybody found a way to accomplish this? I would
> > appreciate if you could send me any examples.
> > Adam M. Feidt
> > GIS Coordinator
> > 8080 Mitchell Rd
> > phone# 952-949-8443
> > fax# 952-949-8334
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
