[mapserver-users] symbology showing line direction
Adam Feidt
afeidt at edenprairie.org
Fri Feb 29 10:06:02 EST 2008
I was hoping it could read ESRI's From and To node structure much like
ArcMap, but by the sounds of it that isn't possible. Shapefile geometry
is saved in the Shape column, which I'm guessing is useless in
Mapserver. What you're saying is I need to create an attribute and
populate it with the angle of the line and use that to define my label
direction?
Adam M. Feidt
GIS Coordinator
City of Eden Prairie
8080 Mitchell Rd
Eden Prairie, MN 55344
phone# 952-949-8443
fax# 952-949-8334
-----Original Message-----
Sent: Friday, February 29, 2008 8:57 AM
To: Adam Feidt
Cc: Fawcett, David; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] symbology showing line direction
A question: how can you derive a line direction by a shp without
having an appropriate attribute?
Giovanni
2008/2/29, Adam Feidt <afeidt at edenprairie.org>:
> David,
> Below is my Layer definition. I've tried a truetype symbol and
label
> with the ANGLE parameter set to AUTO or FOLLOW. Neither case pointed
out
> actual shapefile line direction. I'm reading an ESRI shapefile so
there is
> no specific column for line direction.
> LAYER
> NAME 'Utilities Sanitary Lines'
> DATA './UtilitiesSanitaryLines.shp'
> TYPE LINE
> STATUS DEFAULT
> CLASSITEM "Function"
> CLASS
> NAME 'Main'
> EXPRESSION ""
> STYLE
> COLOR 85 255 0
> SYMBOL "plainline"
> SIZE 2
> END
> END # end class
> CLASS
> NAME 'Low Pressure'
> EXPRESSION "Low Pressure"
> STYLE
> COLOR 255 85 0
> SYMBOL "plainline"
> SIZE 2
> END
> END # end class
> CLASS
> NAME 'Sub Trunk'
> EXPRESSION "Sub Trunk"
> STYLE
> COLOR 85 255 0
> SYMBOL "plainline"
> SIZE 2
> END
> END # end class
> CLASS
> NAME 'Trunk'
> EXPRESSION "Trunk"
> STYLE
> COLOR 112 168 0
> SYMBOL "plainline"
> SIZE 2
> END
> END # end class
> CLASS
> NAME 'Force Main'
> EXPRESSION "forcemain"
> STYLE
> COLOR 255 170 0
> SYMBOL 'dashed1'
> SIZE 2
> END
> END # end class
> CLASS
> NAME 'Private'
> EXPRESSION "private"
> STYLE
> COLOR 161 33 240
> SYMBOL 'plainline'
> SIZE 2
> END
> END # end class
> END #end layer
> Adam M. Feidt
> GIS Coordinator
> 8080 Mitchell Rd
> phone# 952-949-8443
> fax# 952-949-8334
> From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
> Sent: Friday, February 29, 2008 8:19 AM
> To: Adam Feidt; mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] symbology showing line direction
> Adam,
> What does your layer definition, with the classes look like?
> Does your data have the direction column properly populated for all
records?
> David.
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf
> Of Adam Feidt
> Sent: Friday, February 29, 2008 8:14 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] symbology showing line direction
> I'm working in a GeoMoose application and trying to display
utility
> lines with the correct line direction via some arrow character or
symbol.
> I've had no luck so far. I've successfully labeled my lines with a
truetype
> font character by defining the TEXT ">" parameter in the CLASS object.
I've
> also tried a pixelmap symbol definition using a .gif file. Both
appear to
> work at first, but when you compare it to the actual line direction it
isn't
> true in all cases. Has anybody found a way to accomplish this? I
would
> appreciate if you could send me any examples.
> Adam M. Feidt
> GIS Coordinator
> 8080 Mitchell Rd
> phone# 952-949-8443
> fax# 952-949-8334
