[mapserver-users] symbology showing line direction
Rodrigo Martín LÓPEZ GREGORIO
rodrigomartin at lopezgregorio.com.ar
Fri Feb 29 10:53:25 EST 2008
Hi.
I'm not sure if I understand what you are trying to do, but if I'm right you
need to draw a > symbol over your lines in the direction of the line. If
this is what you want you must define a SYMBOL and set it to your line. The
trick to get the symbol drawed along line direction is to set the symbol GAP
with a negative value. By example:
SYMBOL
NAME "arrow"
TYPE truetype
FONT arialbd
* CHARACTER '»'*
FILLED true
ANTIALIAS true
*GAP -100*
END
where the -100 value represents that CHARACTER must be drawed in the
direction of the line (the minus) and CHARACTER must be drawed with a GAP of
100 map units between each other (In my case, my map unit is meters, so
there will not be two > symbols for the same line in a radius of 100
meters).
Then you must use this symbol in your line layer definition as SYMBOL for
your CLASS element. Something like:
LAYER
STYLE
ANTIALIAS TRUE
COLOR 255 255 255
OUTLINECOLOR 0 0 0
*SYMBOL "arrow"*
SIZE 15
END
END
I hope it works for you. Sorry my english.
Rodrigo.
On Fri, Feb 29, 2008 at 3:06 PM, Adam Feidt <afeidt at edenprairie.org> wrote:
> I was hoping it could read ESRI's From and To node structure much like
> ArcMap, but by the sounds of it that isn't possible. Shapefile geometry
> is saved in the Shape column, which I'm guessing is useless in
> Mapserver. What you're saying is I need to create an attribute and
> populate it with the angle of the line and use that to define my label
> direction?
> Adam M. Feidt
> GIS Coordinator
> City of Eden Prairie
> 8080 Mitchell Rd
> Eden Prairie, MN 55344
> phone# 952-949-8443
> fax# 952-949-8334
> -----Original Message-----
> From: G. Allegri [mailto:giohappy at gmail.com]
> Sent: Friday, February 29, 2008 8:57 AM
> To: Adam Feidt
> Cc: Fawcett, David; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] symbology showing line direction
> A question: how can you derive a line direction by a shp without
> having an appropriate attribute?
> Giovanni
> 2008/2/29, Adam Feidt <afeidt at edenprairie.org>:
> > David,
> > Below is my Layer definition. I've tried a truetype symbol and
> label
> > with the ANGLE parameter set to AUTO or FOLLOW. Neither case pointed
> out
> > actual shapefile line direction. I'm reading an ESRI shapefile so
> there is
> > no specific column for line direction.
> > LAYER
> > NAME 'Utilities Sanitary Lines'
> > DATA './UtilitiesSanitaryLines.shp'
> > TYPE LINE
> > STATUS DEFAULT
> > CLASSITEM "Function"
> > CLASS
> > NAME 'Main'
> > EXPRESSION ""
> > STYLE
> > COLOR 85 255 0
> > SYMBOL "plainline"
> > SIZE 2
> > END
> > END # end class
> > CLASS
> > NAME 'Low Pressure'
> > EXPRESSION "Low Pressure"
> > STYLE
> > COLOR 255 85 0
> > SYMBOL "plainline"
> > SIZE 2
> > END
> > END # end class
> > CLASS
> > NAME 'Sub Trunk'
> > EXPRESSION "Sub Trunk"
> > STYLE
> > COLOR 85 255 0
> > SYMBOL "plainline"
> > SIZE 2
> > END
> > END # end class
> > CLASS
> > NAME 'Trunk'
> > EXPRESSION "Trunk"
> > STYLE
> > COLOR 112 168 0
> > SYMBOL "plainline"
> > SIZE 2
> > END
> > END # end class
> > CLASS
> > NAME 'Force Main'
> > EXPRESSION "forcemain"
> > STYLE
> > COLOR 255 170 0
> > SYMBOL 'dashed1'
> > SIZE 2
> > END
> > END # end class
> > CLASS
> > NAME 'Private'
> > EXPRESSION "private"
> > STYLE
> > COLOR 161 33 240
> > SYMBOL 'plainline'
> > SIZE 2
> > END
> > END # end class
> > END #end layer
> > Adam M. Feidt
> > GIS Coordinator
> > 8080 Mitchell Rd
> > phone# 952-949-8443
> > fax# 952-949-8334
> > From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
> > Sent: Friday, February 29, 2008 8:19 AM
> > To: Adam Feidt; mapserver-users at lists.osgeo.org
> > Subject: RE: [mapserver-users] symbology showing line direction
> > Adam,
> > What does your layer definition, with the classes look like?
> > Does your data have the direction column properly populated for all
> records?
> > David.
> > From: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf
> > Of Adam Feidt
> > Sent: Friday, February 29, 2008 8:14 AM
> > To: mapserver-users at lists.osgeo.org
> > Subject: [mapserver-users] symbology showing line direction
> > I'm working in a GeoMoose application and trying to display
> utility
> > lines with the correct line direction via some arrow character or
> symbol.
> > I've had no luck so far. I've successfully labeled my lines with a
> truetype
> > font character by defining the TEXT ">" parameter in the CLASS object.
> I've
> > also tried a pixelmap symbol definition using a .gif file. Both
> appear to
> > work at first, but when you compare it to the actual line direction it
> isn't
> > true in all cases. Has anybody found a way to accomplish this? I
> would
> > appreciate if you could send me any examples.
> > Adam M. Feidt
> > GIS Coordinator
> > 8080 Mitchell Rd
> > phone# 952-949-8443
> > fax# 952-949-8334
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080229/463d5f9c/attachment-0001.html
