PROJ support in MS 4.4.1 on IIS
Ben Madin
ben at REMOTEINFORMATION.COM.AU
Thu Jan 3 09:11:31 EST 2008
G'day all,
I am adding some functionality to system (Windows NT 5.2 / Microsoft-
IIS/6.0) on which I can change very little outside the web tree. The
system has php/mapscript 4.4.1 and SUPPORTS=PROJ.
However, when I try :
$projInObj = ms_newprojectionobj("init=epsg:$from_proj");
I get :
Fatal error: [MapServer Error]: msProcessProjection(): No such file
or directory
I gather from docs etc this is probably a path error to find the proj
directory, which can either be moved to somewhere in the path, or a
path setting made, or a PROJ_LIB environment variable set.
Being an apache background myself, I was hoping someone might know
the most straightforward ways to:
a) find the proj directory, and
b) address the issue of mapscript not being able to find it: can I
use the config parameter without calling a map file? (I only want to
reproject points on this page?)
It is all working fine on the development machine, using the ms4w 4.8
platform.
Thanks In advance.
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
ben at remoteinformation.com.au
Out here, it pays to know...
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080103/01144b7b/attachment.html
