wide lines not complete at the edges
rich.fromm
nospam420 at YAHOO.COM
Thu Jan 3 20:42:51 EST 2008
I think this is likely a bug, but I'm first posting to the mailing list to
see if there might be some way I can control this with via my map file.
This is best seen by a picture. [Hopefully attaching files worked; I
haven't attached files to msgs here before.]
What's going on is that it looks like the end of a line is determined by the
point at which the center of the line reaches the edge of the map, not the
points at which the edges of the line reach the edge of the map. This is
significant if you have a line wider than 1 pixel, and it becomes more
significant as the angle between the line and the edge becomes shallower.
In the attached images, the road network is rectangular, but offset a bit
from a pure N/S/E/W grid. Look at what happens to the roads at the edges.
They look like they end prematurely.
This happens when rendered in both AGG and GD. *.map files are pasted
inline below.
--- begin streetbug.agg.map ---
MAP
NAME streetbug-agg
IMAGETYPE AGG_Q
OUTPUTFORMAT
NAME 'AGG_Q'
DRIVER AGG/PNG
IMAGEMODE RGB
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "QUANTIZE_COLORS=256"
END
EXTENT -122.2914 37.8396 -122.2892 37.841
ANGLE 0
SIZE 640 480
IMAGECOLOR 204 204 204
LAYER
NAME LocalRoads
STATUS DEFAULT # DEFAULT means on. change to OFF to enable
via URL parameter (&layer=foo)
TYPE LINE
CONNECTIONTYPE postgis
CONNECTION "dbname=navteq user=navteq host=agua"
DATA "the_geom FROM streets"
CLASS
NAME "Local Roads"
STYLE
COLOR 248 248 248
WIDTH 11
END
END
END
END
--- end streetbug.agg.map ---
--- begin streetbug.gd.map ---
MAP
NAME streetbug-gd
IMAGETYPE PNG
ANGLE 0
SIZE 640 480
LAYER
NAME LocalRoads
TYPE LINE
CLASS
NAME "Local Roads"
STYLE
COLOR 248 248 248
WIDTH 11
END
END
END
END
--- end streetbug.gd.map ---
View this message in context: http://www.nabble.com/wide-lines-not-complete-at-the-edges-tp14609249p14609249.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
