WFS request options
nelson guda
nelson.guda at GMAIL.COM
Fri Jan 4 16:59:25 EST 2008
Thanks Josh,
I looked over the WMS GetFeatureInfo request, and this is exactly
what I need. For some reason, though the only data I am getting back
looks like this:
GetFeatureInfo results:
Layer 'ira_fill2'
Feature 689:
The feature number appears to correspond to the correct place in the
dbf file, but none of the rest of the feature data is being
returned. I don't understand. Does anyone have any ideas?
thanks,
nelson
Here is the mapfile and request that I made:
Request:
http://thewildwoodstudios.com/cgi-bin/mapserv?map=../roadlessland/
maps/
ira.map&REQUEST=GetFeatureInfo&SERVICE=WMS&reaspect=false&VERSION=1.1.1&
LAYERS=ira_fill2&STYLES=default&FORMAT=image/
gif&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:
4326&WIDTH=256&HEIGHT=256&QUERY_LAYERS=ira_fill2&x=254&y=165&BBOX=-122.1
6796875,46.37725420510028,-122.080078125,46.4378568950242
Mapfile:
MAP
NAME "Roadless"
STATUS ON
SIZE 800 600
STATUS ON
EXTENT -124.40950012207 18.2457218170166 -65.7071533203125
49.0011405944824
IMAGETYPE PNG
SHAPEPATH "../shapefiles"
FONTSET ../fonts/fonts.txt
PROJECTION
"init=epsg:54004"
END
WEB
IMAGEPATH "/tmp/"
IMAGEURL "/tmp/"
METADATA
"wms_title" "ira_wms"
"wms_onlineresource" "http://thewildwoodstudios.com/cgi-bin/
mapserv?map=../roadlessland/maps/ira.map&"
"wms_srs" "EPSG:4326 EPSG:54004 EPSG:4269"
END
END
LAYER
NAME "ira_fill2"
TYPE POLYGON
METADATA
"wms_title" "ira_fill2"
"wms_srs" "EPSG:4326 EPSG:54004"
END
PROJECTION
"init=epsg:4269"
END
DATA ira_by_name_nad83
STATUS ON
TRANSPARENCY 75
LABELITEM "NAME"
LABELMAXSCALE 1000000
TEMPLATE "query.html"
TOLERANCE 3
TOLERANCEUNITS PIXELS
DUMP TRUE
CLASSITEM "ID"
CLASS
STYLE
COLOR 0 255 0
END
LABEL
COLOR 0 0 0
OUTLINECOLOR 255 255 255
MINFEATURESIZE 40
TYPE TRUETYPE
FONT arial-narrow-italic
SIZE 8
ANTIALIAS TRUE
POSITION cc
PARTIALS FALSE
MINDISTANCE 300
WRAP '/'
END
END
END
END
On Jan 4, 2008, at 10:48 AM, Josh Livni wrote:
> Nelson,
> Using this method, you don't want to make a WFS request - you want
> to make a WMS request. The mapserver site has documentation on how
> to set up your mapfile to respond to WMS requests (http://
> mapserver.gis.umn.edu/docs/howto/wms_server) as well as the
> template (which can be very simple for your use case).
> There's a thread on the google groups list about using
> getFeatureInfo, but since the guy's WMS is down it's probably not
> the best example (though you could still look at his code).
> http://openlayers.org/dev/examples/getfeatureinfo.html is another
> example that you could probably start with for assistance on the
> client side -- you'd need to modify it to work with Google Maps (eg
> using Google's methods to get at their bbox and other criteria
> while creating the queryUrl, and to parse the result) but the
> concept is the same, so this should get you started.
> Also - glad to hear my old comments helped on the roadlessland site
> - it looks nice.
> Cheers,
> -Josh
> PS - Please be sure to CC the mapserver list if this doesn't make
> sense - others here may well have better ideas on how to help than
> me, and chances are if you want to know something, others may be in
> the same boat, and thus find the thread helpful.
> nelson guda wrote:
>> Hi again, Josh,
>> I just tried "DescribeFeatureType", which works but the response
>> only give the names of the variables. Any idea on how to get the
>> actual data about those variables?
>> many thanks,
>> nelson
>> DescribeFeatureType response:
>> <element name="ira"
>> type="ms:iraType"
>> substitutionGroup="gml:_Feature" />
>> <complexType name="iraType">
>> <complexContent>
>> <extension base="gml:AbstractFeatureType">
>> <sequence>
>> <element name="msGeometry"
>> type="gml:GeometryPropertyType" minOccurs="0" maxOccurs="1"/>
>> <element name="NAME" type="string"/>
>> <element name="ID" type="string"/>
>> </sequence>
>> </extension>
>> </complexContent>
>> </complexType>
>> On Jan 4, 2008, at 8:53 AM, Josh Livni wrote:
>>> This doesn't answer you question exactly, but have you considered
>>> using a WMS getFeatureInfo request instead? Then you can use a
>>> simple template.html to decide which attributes you want to
>>> return for later parsing. I've done this a few times myself with
>>> Google Maps.
>>> -Josh
>>> nelson guda wrote:
>>>> Hi all,
>>>> I have an odd request regarding WFS capabilities. Is it
>>>> possible to have a WFS mapserver request return gml results
>>>> without the geometry data?
>>>> I know that this seems odd, but it makes sense for what I am
>>>> doing. I am using a WMS overlay to serve tiles for a large
>>>> dataset to an overlay on google maps. In order to query
>>>> specific polygons from that dataset (a shapefile), I am using a
>>>> WFS GetFeature request. All I need is the id and other
>>>> parameters of the feature, but not the geometry data (because it
>>>> is already there from the WMS. Right now I am just parsing out
>>>> the info I need from the gml at the server level, but it would
>>>> be much faster if I could get the WFS to return only the feature
>>>> info minus the geometry data. Is this possible?
>>>> Thanks, and thanks for your previous help.
>>>> nelson
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080104/64eaa5d3/attachment.html
