demo map
mapserver at UNIXPLANET.BIZ
Wed Jan 9 15:44:51 EST 2008
I just downloaded the demo from the following url and it suppose to work
with version 4:
http://mapserver.gis.umn.edu/download/current/
I changed the first part as you directed, but there is no hidden input
for map_web, so I just added it
but still the same error.
any idea ?
is there any demo based on php ?
Thanks
Pericles S. Nacionales wrote:
> Sounds like you have an older version of demo. Edit the index.html
> and replace the following lines:
> <select name="map_web_template" size="1">
> <option value="itasca_basic.html"> Basic Application
> <option value="itasca_adds_scalebar.html"> -- Adds
> second scalebar
> <option value="itasca_adds_pan.html"> -- Adds pan
> controls
> <option value="itasca_adds_frames.html"> -- Adds
> frames
> <option value="itasca_adds_dhtml.html"> -- Adds
> dhtml rubber-band box
> </select>
> with these:
> <select name="map_web" size="1">
> <option value="template itasca_basic.html"> Basic Application
> <option value="template itasca_adds_scalebar.html">
> -- Adds second scalebar
> <option value="template itasca_adds_pan.html"> --
> Adds pan controls
> <option value="template itasca_adds_frames.html">
> -- Adds frames
> <option value="template itasca_adds_dhtml.html"> --
> Adds dhtml rubber-band box
> </select>
> Also change these lines:
> <input type="hidden" name="map_web_imagepath"
> value="/ms4w/tmp/ms_tmp/">
> <input type="hidden" name="map_web_imageurl" value="/ms_tmp/">
> to these:
> <input type="hidden" name="map_web" value="imagepath
> /ms4w/tmp/ms_tmp/">
> <input type="hidden" name="map_web" value="imageurl /ms_tmp/">
> Look for RFC-31 for more info.
> Cheers!
> -Perry
> MapServer wrote:
>> Hello
>> I have installed map server but while I am trying to test the demo
>> map I get following error :
>> Content-type: text/html msReturnPage(): Unable to access file. set in
>> index.html
>> and also I noticed that png files have been created in root of demo
>> with following names:
>> [root at firstone workshop-5.0]# ls -la set*
>> -rw-r--r-- 1 apache apache 25840 Jan 9 11:57 set in
>> -rw-r--r-- 1 apache apache 422 Jan 9 11:57 set in
>> -rw-r--r-- 1 apache apache 353 Jan 9 11:57 set in
>> -rw-r--r-- 1 apache apache 163 Jan 9 11:57 set in
>> here is my changes to index.html located in workshop-5.0
>> // EDIT THE NEXT 2 LINES TO MATCH YOUR SETUP
>> var snippet = "IMAGEPATH '/var/www/html/workshop-5.0/tmp/'";
>> snippet += " IMAGEURL '/tmp/'";
>> snippet += " TEMPLATE " + template;
>> document.demo.map_web.value = snippet;
>> <input type="hidden" name="map"
>> value="/var/www/html/workshop-5.0/itasca.map">
>> <input type="hidden" name="program" value="/cgi-bin/mapserv">
>> <input type="hidden" name="root"
>> value="/var/www/html/workshop-5.0/">
