still not getting to the interactive html
SUBSCRIBE MAPSERVER-USERS mapuser
map.user at YAHOO.COM
Mon Jan 14 09:00:41 EST 2008
hi,
i am still not getting onto the interactive map, Example1-9.html of
tutorial, link is:
http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?
map=/ms4w/apps/tutorial/htdocs/example1-
9.map&layer=states&layer=modis
i have checked the "imagepath" and "imageurl" for mapfile. i can get
the image file if i use a static map with mode set to "browse" at the
specified location
in "imagepath". i think there is something wrong with the "imageurl"
may be.
i have my
1. html page and mapfile at location
="C:\ms4w\Apache\htdocs\chk\*.html/map"
2. the tmp directory at location = "C:\ms4w\apache\htdocs\chk\tmp"
In ms4w/apache/log/error.log i get:
[Thu Jan 10 09:19:31 2008] [error] [client 127.0.0.1] File does not
exist: C:/ms4w/Apache/htdocs/chk/[img], referer:
http://localhost/chk/example1-9.html
i access the page as: "http://localhost/chk/example1-9.html" with no
image for the browse mode, when i click the interactive form part i get
this
msEvalRegex(): Regular expression error. String ([map]) failed
expression test.
my html page is:
<html>
<head>
<title>MapServer 5.x Tutorial</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-
8859-1">
<link type="text/css" rel="stylesheet" href="ms35.css" />
</head>
<body bgcolor="#FFFFFF" text="#000000">
<table align="center" width="680" border="0">
<tr>
<td>
<h3 align="center">
Example 1.9: Interactive Maps and the Browse Mode
</h3>
<div align="center">
<img border="1" src="/cgi-bin/mapserv.exe?
map=/ms4w/Apache/htdocs/chk/db.map&layer=states&mode=map" />
</div>
<p align="left">The map above was created in "map"
mode. It is
a static map (it doesn't change when you click on it).
</p>
<!-- START OF MAPSERVER FORM -->
<form name="mapserv" method="GET" action="/cgi-
bin/mapserv.exe">
<!-- HIDDEN MAPSERVER CGI VARIABLES -->
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="imgxy" value="[center]">
<input type="hidden" name="zoom" value="0">
<input type="hidden" name="layer" value="states">
<input type="hidden" name="mode" value="browse">
<table border="1" cellpadding="0" cellspacing="0">
<tr>
<td>
<!-- THE INTERACTIVE, DYNAMICALLY CREATED
MAP -->
<input type="image" name="img" src="[img]"
width="400" height="300">
</td>
</tr>
</table>
</div>
</form>
<!-- END OF MAPSERVER FORM -->
<p align="left">Now, have a look at the mapfile:<br>
<iframe width="100%" src="db.map"></iframe></p>
</td>
</tr>
</body>
</html>
my mapfile is:
MAP
NAME db
IMAGETYPE PNG
EXTENT 246658.296875 56638.5 246745 56743.30078125
SIZE 800 600
IMAGECOLOR 255 255 255
FONTSET "C:/ms4w/Apache/htdocs/chk/fonts/fonts.list"
WEB
TEMPLATE 'C:/ms4w/Apache/htdocs/chk/example1-9.html'
IMAGEPATH 'C:/ms4w/apache/htdocs/chk/tmp/ms_tmp/'
IMAGEURL 'http://localhost/chk/tmp/ms_tmp/'
# have also tried with IMAGEURL /tmp/ms_tmp/ and /ms_tmp/
END
PROJECTION
"proj=tmerc"
"lat_0=49"
"lon_0=-2"
"k=0.999601"
"x_0=400000"
"y_0=-100000"
"ellps=airy"
"units=m"
"no_defs "
END #end projection
#_______________________________________________________
_____________
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
NAME states
CONNECTIONTYPE postgis
CONNECTION "user=***** password=****** dbname=*****
host=localhost port=5432"
DATA "geom from table"
TYPE POLYGON
STATUS OFF
CLASS
NAME "buildings"
EXPRESSION ('[var]' = 'Buildings')
STYLE
COLOR 255 193 132
OUTLINECOLOR 255 0 0
END
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS
END # All map files must come to an end just as all other things must
come to...
please have a look at that, really concerned.
thanks
map.user
