still not getting to the interactive html
Pericles S. Nacionales
naci0002 at UMN.EDU
Mon Jan 14 13:09:11 EST 2008
Change your IMAGEURL line to:
IMAGEURL "/chk/tmp/ms_tmp/"
Remember IMAGEURL is relative to your web server's root. It's probably
not well described in the mapfile reference documentation but that's the
first place I'd check if I where you.
-Perry
SUBSCRIBE MAPSERVER-USERS mapuser wrote:
> hi,
> i am still not getting onto the interactive map, Example1-9.html of
> tutorial, link is:
> http://biometry.gis.umn.edu/cgi-bin/mapserv.exe?
> map=/ms4w/apps/tutorial/htdocs/example1-
> 9.map&layer=states&layer=modis
> i have checked the "imagepath" and "imageurl" for mapfile. i can get
> the image file if i use a static map with mode set to "browse" at the
> specified location
> in "imagepath". i think there is something wrong with the "imageurl"
> may be.
> i have my
> 1. html page and mapfile at location
> ="C:\ms4w\Apache\htdocs\chk\*.html/map"
> 2. the tmp directory at location = "C:\ms4w\apache\htdocs\chk\tmp"
> In ms4w/apache/log/error.log i get:
> [Thu Jan 10 09:19:31 2008] [error] [client 127.0.0.1] File does not
> exist: C:/ms4w/Apache/htdocs/chk/[img], referer:
> http://localhost/chk/example1-9.html
> i access the page as: "http://localhost/chk/example1-9.html" with no
> image for the browse mode, when i click the interactive form part i get
> this
> msEvalRegex(): Regular expression error. String ([map]) failed
> expression test.
> my html page is:
> <html>
> <head>
> <title>MapServer 5.x Tutorial</title>
> <meta http-equiv="Content-Type" content="text/html; charset=iso-
> 8859-1">
> <link type="text/css" rel="stylesheet" href="ms35.css" />
> </head>
> <body bgcolor="#FFFFFF" text="#000000">
> <table align="center" width="680" border="0">
> <tr>
> <td>
> <h3 align="center">
> Example 1.9: Interactive Maps and the Browse Mode
> </h3>
> <div align="center">
> <img border="1" src="/cgi-bin/mapserv.exe?
> map=/ms4w/Apache/htdocs/chk/db.map&layer=states&mode=map" />
> </div>
> <p align="left">The map above was created in "map"
> mode. It is
> a static map (it doesn't change when you click on it).
> </p>
> <!-- START OF MAPSERVER FORM -->
> <form name="mapserv" method="GET" action="/cgi-
> bin/mapserv.exe">
> <!-- HIDDEN MAPSERVER CGI VARIABLES -->
> <input type="hidden" name="map" value="[map]">
> <input type="hidden" name="imgext" value="[mapext]">
> <input type="hidden" name="imgxy" value="[center]">
> <input type="hidden" name="zoom" value="0">
> <input type="hidden" name="layer" value="states">
> <input type="hidden" name="mode" value="browse">
> <table border="1" cellpadding="0" cellspacing="0">
> <tr>
> <td>
> <!-- THE INTERACTIVE, DYNAMICALLY CREATED
> MAP -->
> <input type="image" name="img" src="[img]"
> width="400" height="300">
> </td>
> </tr>
> </table>
> </div>
> </form>
> <!-- END OF MAPSERVER FORM -->
> <p align="left">Now, have a look at the mapfile:<br>
> <iframe width="100%" src="db.map"></iframe></p>
> </td>
> </tr>
> </body>
> </html>
> my mapfile is:
> MAP
> NAME db
> IMAGETYPE PNG
> EXTENT 246658.296875 56638.5 246745 56743.30078125
> SIZE 800 600
> IMAGECOLOR 255 255 255
> FONTSET "C:/ms4w/Apache/htdocs/chk/fonts/fonts.list"
> WEB
> TEMPLATE 'C:/ms4w/Apache/htdocs/chk/example1-9.html'
> IMAGEPATH 'C:/ms4w/apache/htdocs/chk/tmp/ms_tmp/'
> IMAGEURL 'http://localhost/chk/tmp/ms_tmp/'
> # have also tried with IMAGEURL /tmp/ms_tmp/ and /ms_tmp/
> END
> PROJECTION
> "proj=tmerc"
> "lat_0=49"
> "lon_0=-2"
> "k=0.999601"
> "x_0=400000"
> "y_0=-100000"
> "ellps=airy"
> "units=m"
> "no_defs "
> END #end projection
> #_______________________________________________________
> _____________
> # Start of LAYER DEFINITIONS ---------------------------------------------
> LAYER # States polygon layer begins here
> NAME states
> CONNECTIONTYPE postgis
> CONNECTION "user=***** password=****** dbname=*****
> host=localhost port=5432"
> DATA "geom from table"
> TYPE POLYGON
> STATUS OFF
> CLASS
> NAME "buildings"
> EXPRESSION ('[var]' = 'Buildings')
> STYLE
> COLOR 255 193 132
> OUTLINECOLOR 255 0 0
> END
> END
> END # States polygon layer ends here
> # End of LAYER DEFINITIONS
> END # All map files must come to an end just as all other things must
> come to...
> please have a look at that, really concerned.
> thanks
> map.user
