edited image not being saved and displayed properly
Fawcett, David
David.Fawcett at STATE.MN.US
Tue Jan 15 09:02:59 EST 2008
Usually this issue is due to the EXTENT or PROJECTION settings. It
sounds like you are really getting a new image with every request, it is
just not showing any data.
Make sure that your own data falls within the bounding box defined by
the EXTENT at the top of the mapfile. The extent is defined in the
units of your spatial reference system. For UTM this is meters, for
lat/long it is decimal degrees, etc.
Also, make sure that the value for UNITS is set to the proper units for
Another thing to check is to see that your layer has a STATUS of
DEFAULT, or you are adding the layer name to the post or get request
(e.g. &layer=myNewLayer)
If this doesn't help, I suggest posting the text from your map file.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of SUBSCRIBE MAPSERVER-USERS mapuser
Sent: Tuesday, January 15, 2008 7:53 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] edited image not being saved and
displayed properly
i have got a bit success in going through the interactive html page. i
have used exampe1-9 of the tutorial, which is working fine, but as
soon as i change the map file to my own data, then i get the full image
only once i.e. at the time of first load. as soon as i click the image
at
any location, i get a blank image, and that is what is saved in the tmp
directory, a blank image.
why my new image is not being saved and displayed, can anyone
please help.
thanks.
