edited image not being saved and displayed properly
SUBSCRIBE MAPSERVER-USERS mapuser
map.user at YAHOO.COM
Tue Jan 15 11:55:13 EST 2008
hi, i have set the EXTENT to the extent of particular postcode. i think
you are right that the extent changes every time when i click, which is
not in the
specified extent.
how can i set the extent values. i want to show that particular area. if i
set the extent value to the extent of my table, then how can i be able
to show the
small area.
my layer status is set to ON
and projection is 27700
units is meters
my mapfile is
MAP
NAME EX1.9_
IMAGETYPE PNG24
UNITS METERS
EXTENT 248029.59375 54095.69921875 248179.609375
54245.703125# EXTENT OF SPECIFIC AREA
SIZE 400 300
#SHAPEPATH "../data"
SYMBOLSET "../symbols/symbols35.sym"
FONTSET "../fonts/fonts.list"
WEB
TEMPLATE 'example1-9.html'
IMAGEPATH '/ms4w/tmp/ms_tmp/'
IMAGEURL '/ms_tmp/'
END
PROJECTION
"proj=tmerc"
"lat_0=49"
"lon_0=-2"
"k=0.999601"
"x_0=400000"
"y_0=-100000"
"ellps=airy"
"units=m"
"no_defs "
END #end projection
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
NAME tarea
CONNECTIONTYPE postgis
CONNECTION "user=postgres password=postgres
dbname=MasterMap host=localhost port=5432"
DATA "geom from topographicarea"
TYPE POLYGON
STATUS ON
PROJECTION
"proj=tmerc"
"lat_0=49"
"lon_0=-2"
"k=0.999601"
"x_0=400000"
"y_0=-100000"
"ellps=airy"
"units=m"
"no_defs "
END #end projection
CLASS
NAME "buildings"
TYPE POLYGON
STATUS ON
EXPRESSION ('[theme]'='Buildings')
STYLE
COLOR 255 196 196
OUTLINECOLOR 0 0 0
END
END #my class end
END #LAYER
END #END MAP
