mapserver error
Lee Keel
lee_keel at TRIMBLE.COM
Wed Jan 16 13:05:31 EST 2008
Timothy,
Here are the OUTPUTFORMAT options I have in my map file. Do they look correct?
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE PC256
TRANSPARENT FALSE
FORMATOPTION "INTERLACE=OFF"
END
OUTPUTFORMAT
NAME "jpg"
MIMETYPE "image/jpeg"
DRIVER "GD/JPEG"
EXTENSION "jpg"
IMAGEMODE RGB
TRANSPARENT FALSE
END
OUTPUTFORMAT
NAME "gif"
MIMETYPE "image/gif"
DRIVER "GD/gif"
EXTENSION "gif"
IMAGEMODE PC256
TRANSPARENT FALSE
END
From: UMN MapServer Users List on behalf of Nolte, Tim
Sent: Wed 1/16/2008 11:49 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] mapserver error
One quick thought that I have since you say that a layer image is
blurred on the bottom portion is that you have FORMATOPTION INTERLACE=ON
set. This turns on interlacing and sometimes I see that it takes a few
seconds on my mapserver to fully render the image. If you want to
prevent this blurring turn that setting off in your Mapfile.
Timothy J Nolte - tnolte at ilpcs.com
Associate Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Lee Keel
Sent: Wednesday, January 16, 2008 11:38 AM
Subject: [UMN_MAPSERVER-USERS] mapserver error
Hello list. I am having a problem and it is beginning to look like
mapserver is behind it somehow. I am using ms4w 2.2.6 to render
postgres data to openlayers. Mapserver is configured to use IIS\CGI
instead of apache. I am actually having 2 problems, but I am not sure
that they are not related. One problem is that sometimes the server
just isn't returning any data for different layers to OpenLayers. I
have talked extensively with the OL guys and have come back to the fact
that if I take the URL that is requesting the information from
mapserver, then I get: "The specified CGI application misbehaved by not
returning a complete set of HTTP headers." The most consistent way I
can reproduce this is to zoom in real close. The second problem I am
having is that when I am getting layer images back, they are blurred on
the bottom portion. It looks like someone took a cloth and just wiped a
whiteboard.
I am about 5 days late on a deadline to have this up and running, so I
am open to try any suggestions that someone may have.
Thanks in advance,
Lee
