loadMap(): Web application error. CGI variable "map" is not
set.
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Tue Jan 22 11:12:37 EST 2008
I had no problems trying this just now with the GMap add-on application
for MS4W. You should do the same steps and check that it works with
that same application:
- download the "PHP/MapScript Sample Application" from
http://www.maptools.org/ms4w/index.phtml?page=downloads.html
- extract that at the same drive root as your existing ms4w install
- edit /htdocs/gmap75_wms.map and remove the MAP parameter from its
onlineresource metadata:
"wms_onlineresource" "http://127.0.0.1/cgi-bin/mapserv.exe?"
- edit /Apache/conf/httpd.conf and add:
SetEnvIf Request_URI "/cgi-bin/mapserv.exe"
MS_MAPFILE=/ms4w/apps/gmap/htdocs/gmap75_wms.map
- restart apache
- try a GetCapabilities request without the MAP parameter:
http://127.0.0.1/cgi-bin/mapserv.exe?SERVICE=wms&VERSION=1.1.1&REQUEST=GetCapabilities
-jeff
cfb wrote:
> Hi again
> I'm having problems with the publication of a WMS. I've copied the
> mapserv.exe and rename it in the cgi-bin folder of ms4w, and included
> "SetEnvIf Request_URI "/cgi-bin/wms_landsat04.exe"
> MS_MAPFILE=D:\ms4w\maps\map\wms-landsat04.map"
> in the httpd.conf.
> I've changed the onlineresource of the header of the .map and also the data
> of each layer object. Finally I've restarted the apache monitor...
> But it doesn't work. At the ms_error file I get:
> loadMap(): Web application error. CGI variable "map" is not set.
> Does anyone knows a solution?
> Thanks!!
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
