Map file with 35,000+ Lines... management issue
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Jan 24 10:28:00 EST 2008
OK, I think there is a simple solution for you, You need to create
tileindexes. tileindexes are a way to group a collection of shapefiles
that have the same content like roads into a single layer. Say you have
a file structure like:
data/city1/roads.shp
data/city2/roads.shp
data/city3/roads.shp
etc
And if you have a layer for each city/roads.shp you can combine all
these into a single layer like this:
find data -name roads.shp -print > roads-idx.in
tile4ms roads-idx.in roads-idx.shp
shptree roads-idx.shp
And in your mapfile create a layer like:
LAYER
TILEINDEX "roads-idx.shp"
# instead of a DATA statement
END
Now all these shapefiles in the tileindex will be considered in a very
efficient manner.
-Steve
riteshambastha wrote:
> Dear Stephen,
> The number of layers exceeded much because I am including each individual
> shapefile multiple times for different Maxcale/Minscale values. So, a
> shapefile is now called by 3-4 layers, each layer having different
> Maxscale/Minscale values.
> I hope I made my point clear.
> Regards,
> Ritz
> Stephen Woodbridge wrote:
>> Ok, I need to ask the obvious question, WHY? do you feel you need 658
>> layers. Is this because you have lots of shapefiles? and most of the
>> layer definitions are the same except for the data source?
>> For Tiger data I have 33000 shapefiles, but I only have about 20+-
>> layers. Are you using tileindexes? Do you know what they are? Just
>> trying to diagnose your situation a little better so we can help.
>> -Steve W
>> ritesh ambastha wrote:
>>> Thanks Bob,
>>> The map file consists of 658 Layers.
>>> It runs with openlayers and postgis.
>>> Now, am trying to sort out the best way for solving this issue.
>>> Your reply helped me to view at the problems+solutions in broad
>>> spectrum..
>>> Warm Regards,
>>> Ritesh
>>> On Jan 24, 2008 1:04 AM, Bob Basques <Bob.Basques at ci.stpaul.mn.us> wrote:
>>>> Ritz,
>>>> Whew, 35k lines, that big. How many layers is that anyway? The
>>>> Googlish
>>>> mapfile I just did only has 1100 lines in it, and that's mostly for
>>>> readability. I could probably get it down to half that size if I tried.
>>>> Don't know what I can contribute as a "Best Practice", because I feel
>>>> that
>>>> in most cases, that form follows function, if you need a capability, you
>>>> build it. Anyway, here are some of my thoughts.
>>>> These same sorts of performance questions crossed my mind too. The
>>>> Googlish
>>>> mapfile I've been working on has 72 separate STYLE definitions for
>>>> example.
>>>> Mostly ranged around threshholding of certain styles. I can see that
>>>> adding
>>>> in the Water bodies, Railroad, Parks, and such, is really going to make
>>>> this
>>>> thing big. I may just do those as separate MapFiles though since
>>>> GeoMoose
>>>> handles things like these separations very nicely.
>>>> These are some of the primary reasons that contributed to the way we've
>>>> built GeoMoose as a client and why it runs against MapServer CGI, so
>>>> that it
>>>> can abstract the layer calls in this fashion. We're running 135+ layers
>>>> internally at the moment, and they all have their own MAPFILE and are
>>>> all
>>>> called separately from the client. It has made life much easier with
>>>> regard
>>>> to MapFile creation and maintenance, since each data custodian handles
>>>> their
>>>> respective MAPFILE. The performance issues are minimized well since
>>>> even
>>>> the data intensive layers are not too bad from a performance standpoint.
>>>> But even my Googlish looking mapfile got prettty big (in my opinion) for
>>>> simply displaying centerlines of streets. I've learned quite a bit
>>>> from
>>>> these exercises about these types of questions. While I have yet to
>>>> attack
>>>> the performance side of things, I anticpate that I'll need to segregate
>>>> the
>>>> data out at differing thresholds in order to gain some performance
>>>> boots.
>>>> We're all about doing dynamic requests here since many of our datasets
>>>> change very frequently, in some cases, down to the minute. I may look
>>>> into
>>>> tiling at some point in the future, but it will still be only for some
>>>> of
>>>> the layers, there will still be a need to have this dynamic request
>>>> structure in place.
>>>> bobb
>>>> Bob Basques
>>>> GIS Systems Developer
>>>> City of Saint Paul, MN
>>>> GISmo
>>>> Powered by
>>>> GeoMOOSE
>>>>>>> riteshambastha <ritesh.linux at GMAIL.COM> wrote:
>>>> Dear Readers,
>>>> I have developed a map file with more than 35,000 Lines. Its size will
>>>> grow
>>>> by double/triple in next few months. Now, I am trying to tune my map
>>>> file by
>>>> removing unwanted lines. Still, I am bit confused about its maintenance.
>>>> Please throw some lights over writing map files by following best
>>>> practices.
>>>> Thanks in advance.
>>>> Regards,
>>>> Ritz
>>>> View this message in context:
>>>> http://www.nabble.com/Map-file-with-35,000+-Lines...-management-issue-tp15048892p15048892.html
>>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
