problem compiling 5.0.1
frequens
frequens at GMAIL.COM
Fri Jan 25 10:08:14 EST 2008
Actually the fix works also with flex 2.5.4a....
Both machines up and running, correctly at a first glance...
BR
frequens
On Jan 25, 2008 3:56 PM, frequens <frequens at gmail.com> wrote:
> Yeep. This solved also the first one.
> The first machine has flex 2.5.33-21 installed (too old?!), the second
> one 2.5.4a (rather old, I agree).
> Is there any way it would work also with the 2.5.4a or alike?
> Upgrading it requires turning the world upside down (production
> machine, glibc, then gnome, then...)
> Thank you very much for all....-)
> BR
> frequens
> On Jan 25, 2008 3:01 PM, Daniel Morissette <dmorissette at mapgears.com> wrote:
> > frequens wrote:
> > > This solves the second one. First one still to go....
> > Um... I think the problem is that maplexer.l has been modified for
> > ticket #2331 but maplexer.c has not been updated in subversion (and in
> > the release), so your system tries to regenerate it using your local
> > copy of flex, which is possibly too old and that explains the errors you
> > get.
> > The release should have contained the updated maplexer.c but it did not.
> > I have generated a new maplexer.c, can you please download it to your
> > local source tree and try building again? You can use the following URL
> > to download it:
> > http://trac.osgeo.org/mapserver/browser/branches/branch-5-0/mapserver/maplexer.c?format=txt
> > If you confirm that this solves the issue then we'll have to release
> > 5.0.2 right away with that fix.
> > Daniel
> > Daniel Morissette
> > http://www.mapgears.com/
