problem compiling 5.0.1
frequens
frequens at GMAIL.COM
Fri Jan 25 09:56:21 EST 2008
Yeep. This solved also the first one.
The first machine has flex 2.5.33-21 installed (too old?!), the second
one 2.5.4a (rather old, I agree).
Is there any way it would work also with the 2.5.4a or alike?
Upgrading it requires turning the world upside down (production
machine, glibc, then gnome, then...)
Thank you very much for all....-)
BR
frequens
On Jan 25, 2008 3:01 PM, Daniel Morissette <dmorissette at mapgears.com> wrote:
> frequens wrote:
> > This solves the second one. First one still to go....
> Um... I think the problem is that maplexer.l has been modified for
> ticket #2331 but maplexer.c has not been updated in subversion (and in
> the release), so your system tries to regenerate it using your local
> copy of flex, which is possibly too old and that explains the errors you
> get.
> The release should have contained the updated maplexer.c but it did not.
> I have generated a new maplexer.c, can you please download it to your
> local source tree and try building again? You can use the following URL
> to download it:
> http://trac.osgeo.org/mapserver/browser/branches/branch-5-0/mapserver/maplexer.c?format=txt
> If you confirm that this solves the issue then we'll have to release
> 5.0.2 right away with that fix.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
