an easy question....
Till Adams
adams at TERRESTRIS.DE
Wed Jan 30 10:24:05 EST 2008
more interesting is the thing with the name of your application... ;-)
>hi,
>this seems not to be a network problem, and have nothing to do with the
>mapserver.
>your URL is only reachable on your local PC (think about the word
>"localhost")
>try to find out your ip address or host name.
>for this you must open the console (start -> run -> write "cmd") and write
>the command "ipconfig" to get information about your ip address or
>"hostname" to get your PCs host name.
>then you can modify your link
>http://[host name]/maplab_projects/gmf_apps/piss/piss.phtml or
>http://[ip address]/maplab_projects/gmf_apps/piss/piss.phtml
>best regards,
>..daniel
>egg wrote:
>>Hi all forum, Well I've done my first work in mapserver, and then using
>>Mapfactory I've got the next URL link:
>>http://localhost/maplab_projects/gmf_apps/_*piss/piss*_.phtml, and this work
>>fine, but just in my Pc when I tried to open in another pc it doesn't
>>work. My question is How can I get that my map created open on any pc?
>>Thanks in advanced.
>>Saludos
terrestris ist umgezogen!
Die neue Adresse ab 01.07.2007 lautet:
Irmintrudisstraße 17, 53111 Bonn
http://www.terrestris.de
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
