[MAPSERVER-USERS] insertLayer()
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Tue Jul 1 15:44:14 EDT 2008
Hans,
You should test every step of your code, for example :
if ($oPuntoSeleccionado->addFeature($oShapePuntos) == -1)
echo "Error";
it would help getting the step which goes wrong.
Guillaume
Hans Castorp a écrit :
> Hi Guillaume, thanks for your help,
> This is the code I'm using in order to create a new points layer (with
> only one point):
> $oMap = ms_newMapObj($szMapFile);
> $oPuntoSeleccionado= ms_newLayerObj($oMap);
> $oPuntoSeleccionado->set("name", "EMPRESAS_ALT");
> $oPuntoSeleccionado->set("type", MS_LAYER_POINT);
> $oPuntoSeleccionado->set("status", MS_ON);
> $oCoordenadas=ms_newLineObj();
> $oShapePuntos=ms_newShapeObj(MS_SHAPE_POINT);
> $oCoordenadas->addXY($x, $y);
> $oShapePuntos->add($oCoordenadas);
> $oPuntoSeleccionado->addFeature($oShapePuntos);
> $oClase=ms_newClassObj($oPuntoSeleccionado);
> $oEstiloPunto=ms_newStyleObj($oClase);
> $oEstiloPunto->set("symbolname", "MARKER_EMPRESA_ALT");
> $oEstiloPunto->set("text", "");
> But I have no results. No errors but no success too.
> P.S. I'm trying to add this funcionallity to a Ka-map based application.
> Thanks in advance.
> -----Mensaje original-----
> De: Guillaume Sueur [mailto:guillaume.sueur at neogeo-online.net]
> Enviado el: martes, 01 de julio de 2008 10:16
> Para: Hans Castorp
> CC: mapserver-users at lists.osgeo.org
> Asunto: Re: [MAPSERVER-USERS] insertLayer()
> I guess you just need a new LayerObj, as described in the mapscript
> documentation
> (http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class) :
> Layer Objects can be returned by the MapObj class, or can be created
> using:
> layerObj ms_newLayerObj(MapObj map [, layerObj layer])
> A second optional argument can be given to ms_newLayerObj() to create
> the new layer as a copy of an existing layer. If a layer is given as
> argument then all members of a this layer will be copied in the new
> layer created.
> You can then play with :
> boolean moveLayerUp(int layerindex)
> Move layer up in the hierarcy of drawing.
> boolean moveLayerDown(int layerindex)
> Move layer down in the hierarcy of drawing.
> array getlayersdrawingorder()
> Return an array containing layer's index in the order which they
> are drawn.
> boolean setlayersdrawingorder(array layeryindex)
> Set the layer's order array. The argument passed must be a valid
> array with all the layer's index.
> Return TRUE on success or else FALSE.
> to set your layer's correct place into the map.
> Hope that helps,
> Guillaume
> > Hi to all,
> > If map->insertLayer() isn't available in php mapscript, how can I insert
> > a runtime created layer using php mapscript???
> > Thanks in advance.
> > Hans Castorp.
> > Enviado desde Correo Yahoo!
> <http://us.rd.yahoo.com/mailuk/taglines/isp/control/*http://us.rd.yahoo.com/evt=52431/*http://es.docs.yahoo.com/mail/overview/index.html>
> > La bandeja de entrada más inteligente.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> No virus found in this incoming message.
> Checked by AVG.
> Version: 7.5.524 / Virus Database: 270.4.3/1527 - Release Date:
> 30/06/2008 18:07
