[mapserver-users] Postgis mapserver sql help
Alexandre Busquets Triola
alex at sigte.udg.edu
Wed Jul 2 04:42:36 EDT 2008
Hi, this is the first time that I write to the list.
I'm working with mapserver and postgis and I have a problem with mpaserver,
if I put this query on postgres
select geom FROM par_vit3 where intersects(
select GeomFromText(
'POLYGON((258000 4485000, 258000 4625800 ,398800 4625800 ,398800
4485000, 258000 4485000))',23031
) as foo
, geom )
works ok
but if I put this
) as foo using SRID=23031
, geom ) using SRID=23031
in maperver not works, this is the error that I have
Warning: [MapServer Error]: prepare_database(): Error executing POSTGIS
DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR
FOR SELECT asbinary(force_collection(force_2d(geom)),'NDR'),OID::text
from par_vit3 where intersects( ( select GeomFromText( 'POLYGON((258000
4485000, 258000 4625800 ,398800 4625800 ,398800 4485000, 258000
4485000))',23031 ) as foo WHERE geom && setSRID('BOX3D(258000
4485000,398800 4625800)'::BOX3D, 23031 )' Postgresql reports the error
as 'ERROR: syntax error at end of input LINE 5: ...tSRID('BOX3D(258000
4485000,398800 4625800)'::BOX3D, 23031 ) ^ ' More Help: Error with
POSTGIS data variable. You specified 'check your .map file'. Standard
ways of specifiying are : (1) 'geometry_column from geometry_table' (2)
'geometry_column from (sub query) as foo using unique column name using
SRID=srid#' Make sure you put in the 'using unique column name' and
'using SRID=#' clauses in. For more help, please in
D:\alex\webs\alex\codorniu\mapscript\parceles2.php on line 172
Warning: [MapServer Error]: msPOSTGISLayerRetrievePK(): Error executing
POSTGIS statement (msPOSTGISLayerRetrievePK():select attname from
pg_attribute, pg_constraint, pg_class where pg_constraint.conrelid =
pg_class.oid and pg_class.oid = pg_attribute.attrelid and
pg_constraint.contype = 'p' and pg_constraint.conkey[1] =
pg_attribute.attnum and pg_class.relname = 'par_vit3 where intersects( (
select GeomFromText( 'POLYGON((258000 4485000, 258000 4625800 ,398800
4625800 ,398800 4485000, 258000 4485000))',23031 ) as foo' and
pg_table_is_visible(pg_class.oid) and pg_constraint.conkey[2] is null in
Thanks
_________________________________________________________________
Servei de Sistemes d'Informació Geogràfica i Teledetecció (SIGTE)
Universitat de Girona
Pl. Ferrater Mora, 1
17071 Girona
Tel. 972 41 80 39 Fax. 972 41 82 30
http://www.sigte.udg.es/
